Results 1 to 12 of 12
Thread: Loud Engine Clicking?
New to Pro-Touring
- Nov 2004
- 78
Hey guys, a little help would be great.
I have a 68 Camaro with a 396 BBC. I just recently got a loud annoying clicking noise (similar to a lose rocker) but I already tightened them down per spec. and the noise is still there. I have a feeling it could be a bad lifter.
As far as I know, I have Hydraulic lifters, and I was told that if the lifter went bad and is not getting oil, then it can make a noise like this.
Please help.
02-15-2005 #2
- Jan 2004
- 87
Did you check your plug gaps and are certain its not just a misfire? I had that happen to be before and had visions of bad lifters etc. in my head and it was a spark plug.
02-15-2005 #3
New to Pro-Touring
- Nov 2004
- 78
Clicking
No, I didn't try that, but I'll take a look this weekend...Thanks for the advice.
02-16-2005 #4I too have a 396 BBC. I just replaced the cam TWICE. First time I swapped cams because it was a solid lift cam. Once installed with new springs I got a severe ticking because I flattened two lobes. I would, if all else fails, pull the manifold so that you get a good view of the valley and inspect all lobes. Bump the motor over until you find the culprit.
02-16-2005 #5
