    Page 2 of 2 FirstFirst 1 2
    Results 21 to 34 of 34
    1. #21
      Phoenix, Az
      Thanks, that was very helpful.
      "I'm dumb enough to ask stupid questions...but just smart enough to recognize a stupid answer"
    2. #22
      Edmonton, Alberta, CANADA
      The post was not so much for you... as for Larry.
      Trying to determine what the difference is with your setup.
      I am posting using IE 6.0.2900.2180
      I am behind a Cysco firewall (hardware and software)
      I posted one from Home using Latest Firefox
      I was behind a Linksys Firewall. Different ISP as well. No issues...
    3. #23
      Phoenix, Az
      No really it was. Several people have uploaded since my issue...I don't know whats going on but it seems to me to be some sort of security/firewall/IE setting on my end... Have been working so I have not had a chance to T/S much on my end yet. Just tried turning off Zonealarm and overiding cookie handling and adjusting internet settings etc. I will have more time in a few days to check it out. any suggestions on what to tweak might help though. THX...T
    4. #24
      Massachusetts
      Same problem
      I have been trying to post a couple of pictures for the past two weeks to both "project updates" and the "Garage" and am having the same issue that it times out and the page is not found. I have tried it from my home pc with cable modem and just tried from my laptop in office on a T1 line, no luck. I guess I'll just keep looking at the pictures myself
      Eric
    5. #25
      Winnipeg, MB
      Quote Originally Posted by Emo69SS
      Eric
      Same here....I can't get a single pic to load.
      Jason
      Buick Motorsports aka No Mercy Motorsports.
      1985 Buick Regal, Pro-Touring inspired to start. Full on pro-touring as time and money permit.
    6. #26
      San Antonio, Tx
      i gave up on uploading pics to the net 4 different PC's and still no luck.
      Instagram: CamaroAJ
    7. #27
      Phoenix, Az
      I have now tried on 3 different P.C.'s changed/adj. and turned off firewalls etc...I gave up! Have emailed Pro-touring but have not received a reply but could be due to wedding etc. I'm just waiting for an answer or breaktrhough of some sort...otherwise I give up!
    8. #28
      Jun 2002
      Long Island, NY
      Hey guys,
      Sorry this problem has not been resolved sooner. Post the exact process you are attempting when trying to post pics in VBgarage, and then what error messages, you are receiving, or what is happening. We should be able to get you set up and posting if we can see exactly what you're doing.
    9. #29
      Jun 2002
      Long Island, NY
      For example, the process I use to post pics is:
      1). Click on User CP
      2). Click on Edit Vbgarage
      3). Click the browse button
      4). Find the picture I'm going to post on my computer
      5). Click Submit
      Save this picture to your computer, and try to post it in your VBgarage. (I just posted the same pic in my Vbgarage, so the size and file type are definitely correct. We can eliminate that variable.)
    10. #30
      San Antonio, Tx
      OK i did what you said to do and it posted just fine. what size and format pic should we be able to upload? i see that one is a .jpg and about under 460 KB. is there any othes like .gif?
      Instagram: CamaroAJ
    11. #31
      Jun 2002
      Long Island, NY
      I'm don't believe it will accept .gifs, but I'm not 100% sure on that. I would say try to shoot for pics in the 800x640 pixel range, and .jpgs only. Those should work. Larry may know the exact limit, I'll see if I can find out.
    12. #32
      Phoenix, Az
      Uploaded the pic of the radiator just fine. Wierd! I have tried making my pics smaller and of .jpg type and I get this error:
      ERROR
      The requested URL could not be retrieved
      While trying to retrieve the URL: https://www.pro-touring.com/forum/vbgarage.php
      The following error was encountered:
      • Zero Sized Reply
      Squid did not receive any data for this request.
      Please visit http://servicerequest.intel.com web page to report an issue if you feel this is incorrect.
      Generated Thu, 02 Jun 2005 05:05:15 GMT by proxy04.ch.intel.com (squid/2.5.STABLE5)
      I will try making some more adjustments to my pics as the radiator pic loads fine. THX...T
    13. #33
      Phoenix, Az
      I had been saving a lower resolution copy of my 1600x1200 pics from Adobe to drop the size down...I had not been adjusting the actual dimension size thus causing an issue uploading. When I went into Adobe and Adjusted the actual dimensions of the pics to approximately 750x500 they loaded great. Thanks alot Ralph...lesson learned!
    14. #34
      Jun 2002
      Long Island, NY
      No problem, glad to hear everything worked out and you can now post pics!!
