    Thread: 86 305 tpi
      Jan 2007
      akron oh
      86 305 tpi
      I want to install this motor into a truck. I have all the wires and computer. I would like some input on good=cheap idea's. I looked up a wire set from summit it's 400$. I would like to use the stock set up if possible.
      do you have any specific questions?
      NY
      Get your hands on the wiring diagram. I know the injectors pull something (power or ground) out of the aldl. The diagram would make the headaches a little less.
      The needs of the many outweigh the needs of the few.
      Use stock computer and loom.Remove all the non engine wiring (AIR . EGR A/C ) leaving only the basic sensors and injectors.
      Good reading
      http://www.chevythunder.com/fuel%20i....%20pg%20A.htm
      http://www.chevythunder.com/fuel%20i....%20pg%20B.htm
      http://www.chevythunder.com/fuel%20i....%20pg%20C.htm
