    Page 8 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
    Results 141 to 160 of 166
    Thread: Dse Stands
    1. #141
      Woodbine, MD
      Well Sunday is the big day! I am going to make them 16" wide and 14" long. I will put up pics when I am all done.
      Douglas Lutes
      1988 Monte Carlo SS
    2. #142
      Woodbine, MD
      Here are the stands I made...
      I had to modify the base of the driver front to make room for the lift alignment plate.
      Douglas Lutes
      1988 Monte Carlo SS
    3. #143
      May 2002
      Northern California
      nice work
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    4. #144
      Nov 2011
      London, UK / San Diego, CA
      Something so simple, yet so awesome. Can't wait to make a set of these when I get back to working on my car.
      Eric
      1969/72 Corvette Coupe - https://www.pro-touring.com/showthre...uring-Corvette
      454 Block / Heads For Sale - https://www.pro-touring.com/showthre...ads-SD-LA-Area
      Corvette Parts & Service:. www.vansteel.com
    5. #145
      Oct 2006
      Carlsbad, CA
      Nice job - well done. Simple is good.
    6. #146
      Aug 2005
      Hamilton, NJ
      the lift is pretty sweet too.
      Scott from NJ.
      Vent Windows Forever! ...
    7. #147
      Jan 2010
      Somewhere out there
      Best $25 ever spent on 4 stands that are multi-functional.
      I used mine to hold up my 200-4R during the vertical part of its rebuild.
    8. #148
      May 2007
      Mooresville, Indiana
      We now have four sets of stands all made a little different. Here's another use...
      This set is 14"x14" and I just used some scrap steel square tube.
    9. #149
      Aug 2012
      Peoria, AZ
      I've got a two post lift at home but I'd like to have a set of these to use to measure, set up, and make alignment adjustments to the car at ride height.
      On a drive on lift or alignment rack, you roll the car back and forth a bit to relax the tire bind in order to let the front suspension relax completely. Has anyone figured out a way to accomplish this when setting the front of the car down on a set of stands like these?
      The only thing I can think of is a steel plate secured to the top of the two front stands and another steel plate on top of that with maybe a layer of oil or grease between them so they'll slide a bit...but there has to be a better way, no? I also need to shim the bottoms of them just a bit in places as my floor isn't exactly level...but that isn't too big of a deal.
      Lance
    10. #150
      Aug 2012
      Peoria, AZ
      I finally finished my crib stands up today. I've got a couple of projects planned for this winter that require the car to be sitting level and at ride height, so I needed to get these ready first.
      Since I plan on using mine mostly for chassis setup and measuring purposes, I needed to build them a bit differently than most of you have. I wanted to have the tops of my stands flat so that the tires sat up on them, not down in them. This will aid in letting me get the car sitting on a perfectly flat and level plane while up in the air enough so that I can get under it and I'll be able to turn the front tires left and right to check caster and what not.
      Since I had an odd assortment of 2x4s and 2x6s on hand, I laid them out and cut them up to make these 18" long x 12" wide. Test stacked to make sure I cut them all right.
      After nailing them together, I measured the track width and wheelbase on my car and marked the floor exactly in the center of my lift posts. Then carefully measured exactly where the center of all 4 tires will sit and marked places on the floor with tape to represent where the stands will sit. This will show me where to park the car before lifting it with the lift to set on the stands. My floor is not level as the sides fall toward the center where the drain is, so I then needed to shim the bottom of the stands to get all four of them plum and level with each other. This took a while but I finally got them all flat and square.
      I marked the stands so I'll know how to put them back in place and I'll clean the floor up real good and remark the tape where they go, then I'll be able to store them out of the way then put them back in exactly the same spots so the car will have a flat level spot to sit on and I'll still be able to get underneath it to make setup changes and adjustments. I'll also be able to set scales on these for four corner weighing and slip plates under the front tires for alignment settings.
      I still have to rig up something to use for wheel chocks to keep the car from rolling and test place the car on them, but for the most part...they are ready to use.
      Lance
    11. #151
      Florida
      Looks good. I would put the full weight of the car on them and recheck to be sure they are still level. Depending how soft the shims and the 2 X's sitting on them are they may crush down a bit.
    12. #152
      Aug 2012
      Peoria, AZ
      Yep, will do. Hopefully they all crush just about the same amount if any at all. Thanks.
      Lance
    13. #153
      Mar 2012
      Texarkana, TX
      Had to make me a set of them as well.
      63 Biscayne
      Schwartz Performance Chassis
      My build thread: https://www.pro-touring.com/showthre...ht=#post916553
    14. #154
      Jul 2012
      Iowa
      You can use ratchet straps that go thru the stands and wrap up around the tire, Ive use that before and it works pretty well.
      Miles Boyer
      The car hobby is dangerous,if the speed doesn't kill you, the cost of parts will.
      91 V8 S10
      88 Cutlass Pro-Tour
      97 Chevy lifted Z-71
      96 Corvette
    15. #155
      Oregon
      Are $4000 worth of wheels required for these? Man I need a better paying job
    16. #156
      Aug 2012
      Peoria, AZ
      Nope, not at all...
      Lance
    17. #157
      Rockford Illinois
      I once worked at a wood shop that built machines out of wood. Seriously, they built a saw out of wood.
      Now I know that people work with the materials they feel comfortable working with which leads to this kind of thinking.
      So right or wrong is not the ideal here. It is a simple wood is good but steel is always real.
      It was a wonderful day when I stepped up and learned how to work with steel, it got so much simpler to get a whole lot stronger.
      Yes Brandon ,it is amazing how long this thread is going!
    18. #158
      Oregon
      How about wood with an aluminum top. Not quite steel but man it sure feels real.
    19. #159
      Sep 2007
      South Brunswick, NJ
      I know this thread is older but just wondering how are you guys getting your car up high enough to put on these stands? My jack at full height only gets my front wheels 9" off the ground with the suspension sagging so this is not much higher then the rhino ramps I already have. Problem is the rhino ramps do not allow alot of room under the car an i want a way to get it higher off the ground to make working under it easier. The jack I have now lifts to about 20.5" and some of the long reach jacks I saw go to alittle over 23 so it's not that big of a difference. How are you guys getting you cars high enough for these taller stands you built. Thanks
      1969 Camaro - LeMans Blue
      383ci ~ M22 4-speed ~ 12-Bolt Posi-3.73
    20. #160
      Beach Park IL
      I built the stands with a total height of 12" but they are in 2 sections, 6" each. So each end goes up 6" and then I crib the jack up and slide in the other section.
      Donny
