    Thread: LQ4/T56 Swap
      Feb 2006
      Southeast Louisiana
      LQ4/T56 Swap
      Can a T56 be bolted up to an LQ4 6.0L? I assume it can since the aluminum blocks and these cast iron blocks are pretty much the same. I'm looking at getting a complete LQ4 with ECM, wiring, accessories, etc. Can the stock ECM be reprogrammed to accept a T56, and can the wiring harness be modified as well? Any help would be greatly appreciated.
      If anyone is doing/has done this particular swap, I would like to discuss it you if possible.
      thanks,
      Chris
      1968 Camaro, 350 SBC, TH350 w/3500 Stall, 12 Bolt, 4.56:1 Gears. Currently in progress...DSE Minitub Kit, DSE front suspension, DSE SFC's, 17" Budniks, Baer front and rear discs.
      http://www.cardomain.com/ride/2391864
      Dunwoody, GA
      Yes, to both your questions. I can not remember off the top of my head if you can simply unbolt the flex plate and bolt a flywheel on. I remember there being talk of a spacer for the 6.0s that were in front of the 4L80E. Sorry, I just don't remember. The ECM is the same for manual or autos, you just have to have it programmed accordingly.
      Trey
      ~ Jon Hammond
