      alignment specs for 68 firebird
      Hello everyone,
      I am looking to get my 68 PT Firebird aligned this weekend and I'm not sure what to tell the alignment shop as far as specs. The car has power steering, been lowered 1 1/2 inches, and has 17x8 rims with low profile tires.
      To add to the fun, I need to bring the specs in degrees, not inches. The alignment machine they use does not allow for measurements to be entered in inches.
      Any help would be greatly appreciated. Thanks in advance
      Auburn, WA
      Modifications?
      This has been discussed before. Have you done a search?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Chapel Hill, NC
      I don't know if the specs for a firebird are the same as the Camaro, but here's a helpful site.
      http://www.pozziracing.com/first_gen....htm#Alignment specs
      Dan
      Chapel Hill, NC
      ***PM me if you're close by and can help with my 65 Mustang Fastback project***
      The only modifications are the ones I listed. I did not do the gulstrand (sp) mod. I did try searching because I figured this has been covered, but wasn't able to find the info I am looking for.
      I also checked out David Pozzi's site, which is great. The only thing is he lists the settings for toe in inches. Does anyone know how to convert inches into degrees?
      Thanks again
      Apr 2008
      Camber and Caster are measured in degrees. Toe is still measured by inches on most machines.
      Tyler
      Everything I post is my personal opinion. When I post under this name I am not a sponsor or business owner any longer, but just a regular car guy like yourself.
