    Results 1 to 1 of 1
      BigStuff3 Crank Reference angle problem
      Just fired my 502 with the following setup:
      MSD-2345 distributor (cam and crank position sensors)
      Dropped in distributor with timing mark at 50 BTDC and pickup eyeballed to line up with sensor.
      Distributor has the 10-degree advanced reluctor in it.
      When I run it, it was at 8 BTDC actual with 32 degrees commanded and the crank reference set to the default of 50.
      I kept progressively lowering the crank reference angle, but got all the way to 0 and still was only at 24 actual for 32 commanded.
      Now what? Can I physically rotate the distributor housing one way or the other? Is it possible I installed the 10-degree advanced reluctor backwards so its 10 late?
      Thanks!
      Dave
