      North Bend, WA
      DIHPB vs. Caliper e-brake systems
      Is there much difference in labor cost with installing a drum-in-hat parking brake system vs. a caliper with built-in e-brake system ?
      What are the major pros and cons of each of these systems ?
      Nov 2004
      Dallas Texas
      E-brakes
      IMO id go with the in hat park brake- very simple the old actuating calipers circa 1980 leaves alot to be desired im using the 98-02 LS1 fbody setup on my car the 93-97 LT1 isnt too bad either you may have to watch caliper mounting in relation to the shock absorbers
      my .02c hope this helps
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      North Bend, WA
      Thanks Zman.
      I found some info after my post that indicated that the DIHPB systems do hold better. It seems like a cleaner install too. All things considered, I came to the same conclusion.
