    Results 1 to 16 of 16
      Jul 2008
      milton, florida
      Project '' Blazin "
      hello everyone , my name is Jim Dion and i own www.birdsandbowties.com, i sell camaro and firebird parts,,,,, well i am not here to sell parts, i am going to build this blazer as a 2 wheel drive pro touring style rig, i cannot find very many done like what i am going to do, i had a tough time finding this one for a 1000.00 ! most of them are 4500 and up and run and drive, i really dont care about that, the motor is knocking in this is why i got it so cheap ! if you look at my website you will see i am not a beginner in this field of work ! what i am looking for now are some pics of some others this body style in 2wd form, i kinda know where i am going with this one, it will have the coys c-5 17 " wheels , i like tt2's but everyone seems to have them nowdays, i do not know of anyone here around pensacola that has a set. i have a 2 wheel drive truck chassis i will cut down to fit this, i am not going to slam it on the ground, i want a driver capable of long trips to key west !!!!!!!!! so if anyone has some pics please post so i can see them,and maybe some ideas of things i can do, i am wanting a 5 inch glass cowl hood, cant seem to find one on ebay so if there is any help please forward, thanks, Jim
      Oct 2007
      Pensacola, FL
      Jim,
      if you need any assistance hit me up thru e-mail or give me a call... I've got an s-10 at the house that is getting bagged and shaved. so if you want to take a look to get some ideas just let me know.
      Ryan
      Feb 2008
      beverly hills florida
      My Blazer
      I'm also just getting started with a 1992 Blazer that was built bin 1996 as a two wheel drive Lt4 with a Vortec Supercharger, It looks like "1996 atyle" and hope to change it to a Pro Touring look.
      Im also in Florida, about 90 miles north of Tampa.
      Bill[/IMG]
      florida
      congrats on the purchase.sounds like a killer deal.before cutting up another chassis and trying to graft it together,cant you just find a 2 wheel drive 1/2 ton front to bolt to that frame?I have had a few older chevy trucks and Im preety sure they stamped the 2 wheel frames with all the bolt holes for the 4 wheel chassis and vice versa.good luck.I looked for one of those for a while a while back and the 2 wheel drive versions are hard to come by.
      Farmington Hills, MI
      Have you ever seen the episode of monster garage where they built the pike's peak truck? I believe it's an older blazer.
      I'd look at that for inspiration.
      http://www.hemitruckclub.com/monster.jpg
      JEFF SHORTT
      -IDEAL STEEL
      Cornettsville, ky
      Quote Originally Posted by Mark Smith
      you could just swap a rcsb truck from 88-99 frame onto it
      that or new drive shaft new trans tail shaft new spindels new torson bar keys etc...
      Jul 2008
      milton, florida
      i have had a lot of people say you could just bolt the front on from a 2 wheel drive, not so at all,the front is completely different, the blazer back section is one of its own also , the part up under the backseat goes up at a different angle than the trucks do , i have a chassis and will be doing the build on it in 2 weeks, i also just got a 9 inch disc brake rear end from a 74 mark 4 lincoln, exactly the same width and has a 5 on 5 bolt pattern the same as the chevy trucks , i already have my plan down on paper and all measurements as i have done this once before on a 87 blazer about 10 years ago, i will post pics when i do the swap, it will be very cool, i plan on power tour next year,,, anyone know where its going, i really dont care, i will be doing the whole thing, as i planned a few times to go but WORK GOT IN THE WAY !! not so this time, i dont care if its going through mexico, I AM GOING !!! Jim
      Jul 2008
      milton, florida
      Quote Originally Posted by billb
      Bill[/IMG]
      i would like to see some pics of your blazer, full size ?
      May 2007
      Tulsa, OK
      Here is a little incentive to get you going!
      '70 Camaro
      '75 Camaro
      '66 Chevelle 'vert
      Jason
      Feb 2008
      hope these show
      [/IMG]
      Yes it's full size,
      Bill
      Jul 2008
      milton, florida
      that yellow blazer is bad for sure, i am not going that crazy with mine, i want to get it done by summer of '09 so i can have fun with it , working on it all the time and never getting to drive it is no fun at all, also i am to busy with my camaro parts buisiness to take forever to build my truck, here is a pic of my old orange extra cab i am mocking this from, it will basicly be the twin only in blazer form !!it had a roller 355 / 700 r4 with a 9inch disc brake rear end and 3.73 gears , ice cold a/c, motor was a mild 355 with edelbrock carb, truck got around 28 mpg on the highway !!! when i bought my house(first one) i had to sell them both the drag car and truck, so now its time for another driver that sweet !
      Jul 2008
      milton, florida
      i just now got around to doin the frame swap, i had to cut the frame at the back where the frame starts to run downwards, i mated it up to the 2 wheel drive frame from the pickup and welded in some gussets to make it sturdy, i also put in a ford 9 inch and it will have disc brakes on it , now i have a 2 wheel drive blazer, and still under a grand in the whole thing !!! the best part is the rear end is from a lincoln mark 4 and it was almost a bolt in, the axles are 5 on 5 pattern and the driveshaft u joint is a 1350 like a gm, it is only 1 inch shorter on each side so i can put a nice deep wheel in the back !
      NC
      Nice build. A little inspiration for myself.
      I recently picked up a 99 Tahoe 2dr 2wd.
      I'm also planning on Coys C-5s, at least for now.
      Keep up the good work.
      Aug 2006
      Easton, PA
      Quote Originally Posted by birdsandbowties
      neat truck, glad to see it moving foward. I've been watching it since you started.
      I was just wondering, though, about your computer. it looks like someone swapped your period key for the comma key. maybe you should fix that.
      Keith C.
      Jul 2008
      milton, florida
      i will post some more pics this week. i am lookingg for a cowl hood 5 inches high,anyone know where i can get a fiberglass bolt on for it ?
      Nov 2004
      LYNCHBURG,OHIO
      I had glasstek custom make me one for my 90' shorty about 7 years ago when the fastest street car shoot out was real big,since they seem so popular Im sure they are cheaper now. I think harwood has them also.
      Greg Tholen
      GT Motorsports
      Dealer for Wilwood,Baer,Viking,Moser,BMR,Earl's
      (937)763-7272
