    Results 1 to 10 of 10
    Thread: what a day!!!
      69LAnd
      what a day!!!
      so i took my car appart last weekend....friday and saturday i put the painted subframe together put all the parts back in the car suspension and everything ,,suspension is way better now real stiff hehe...now on my way to san francisco its all ok goin 110 on the bay bridge saturday night hehe ....drove arround the pier andbroadway ate at north beach...get back on the car ...guy at the valet parkin did a small burn out i was like wtf ...i guess that was his tip haha...now im driving on a main street (vaness) all of a sudden i hear a weird noise...the classic slap noise of a wheel about to come lose....stopped and i noticed 2 lug nuts broke off and the rest were lose......now before these i noticed the lugs were lose before on all wheels .....i have boyd coddingtons and gorilla lug nuts ....and long studs ...did I do something wrong ? Im mad ...need new wheel now and another hub
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
      Jul 2003
      allen, texas
      are you re torquing them after 50 miles from when they are put on, and do you have wheel spacers these can cause loose and broken studs in addition to not applying enough torque
      69LAnd
      car didnt even have 50 miles =I ...and no spacer at first i mounted them with a half inch snap on gun the second time i torqued them down @ 85ft pounds as told ...with an electronic snap on wrench so im sure it was accurate...so now i dont know what could be the problem =I
      Rick M.
      hMMMMMMsss....
      Jun 2004
      Tacompton
      maybe
      . my horror story. I did all the entire pro touring and restoration treatment on my 68 camaro. Well after I stopped using the car as my daily driver I decided to swap out the rear for a 3.73 eaton posi rear end and a set of hotckis multi <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=5&k=leaf%20springs" onmouseover="window.status='<a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=5&k=leaf%20springs" onmouseover="window.status='leaf springs'; return true;" onmouseout="window.status=''; return true;">leaf springs</a>'; return true;" onmouseout="window.status=''; return true;">leaf springs</a>. Well I had work at 1 p.m and started at 9 a.m. After running a little late I slapped the wheels on the car and snugged the lugs up before I went in to eat. While I was eating my brother lowered the car and put all tools and the jack inside the garage so that he could close up the garage and leave. Well while inside my boss called me and told me to hurry up as they were very busy and needed lots of help. So I hurried eating got dressed and hopped in the camaro. I never torqued down the wheels and ended up losing a quarter panel over it. One mistake I will never do again. I really didnt care because the quarter has rust bubbles coming through and it needed to be done anyway. So to pass on an important lesson that I was taught. Always torque your <a s hrelug%20nuts" Also could it possibly be that your lug nuts got stripped somehow?
      69LAnd
      well thats the thing i did check all of them i gotta admit i did do it in a hurry because i didnt wanna take the boring ss lol so i wanted to finish this one and i for sure checked the torque and i did it on all wheels for this reason that it happened before ...when the tow truck brought the car home i checked again and lugs were lose again!!! ughzzz
      Rick M.
      hMMMMMMsss....
      Jun 2004
      Tacompton
      weird
      Thats weird sorry I cant help.I sure someone here will have the answer. By the way sorry about what happened. I know when it happened to me it felt like a kick in the gut
      Oakland CA
      Rick thats horrible! Sorry to hear that. Dont let it stop you cause i still want to see that beast on the rode....
      David
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Boston, MA
      Rick, I feel your pain! I lost a rear wheel at 1am on HWY 101 just North of Novato doing about 70! I was in my 64 Chevelle when I saw sparks outside my drivers side window.
      I had an eaton pro-posi unit in my 12blt. Being that it was more than a little stiff on the street, when I made slow turns it would ratchet around a corner. Not realizing it had loosened my lugs, I lost two on the way home that night. On the 101 the stud's snapped off. I was one lucky MF though. The hub ended up just grinding the crap out of the inner wheel, the tire didn't blow, and I saved the quarter pannel. (This was only a few months after I had painted it too!) 4:30am I arrived back home on the hook, which wasn't totaly uncommon for me, lol. The next weeekend I pulled the axle, pressed new studs into it, had the wheel re-balanced (only damaged on the inside lip and you couldn't see the damage from the outside and it had worn smooth), and put it all back together. I think I was out mabye $40 in the end.
      I was one Lucky MF. I learned to use the Ford gear slick lube in addition to the gear oil. Solved the problem with the posi and I never had to worry about it again.
      Another suggestion is to not use any type of impact wrench on wheel lugs. We had an old 85 Chevy Desiel that we elongated the studs on by using an impack wrench. Not good. It may have been a fluke, but now we make sure that we only use a hand torque wrench with all our car wheels now.
      Oh, make sure you have APR studs too. It's just safe insurance. I think summit sells them in packs of 4 for about $5.
      Hope this helps!
      ~Ryan
      Jan 2003
      Arizona
      Quote Originally Posted by gEtyOpAPiOn
      stopped and i noticed 2 lug nuts broke off and the rest were lose......now before these i noticed the lugs were lose before on all wheels .....i have boyd coddingtons and gorilla lug nuts ....and long studs ...did I do something wrong ?:
      Rick,
      Glad to hear that nothing serious happened. If the lug nuts have come loose on all the wheels, I would have to assume that your lug nuts are incompatible with your wheels and/or wheel studs.
      1) More than likely, the nuts are a little too short for the length of your wheel studs. You mentioned long studs. As such they will bottom out on the face of the stud before they will fully clamp on the wheel. This can also leave you with the impression that they are adequately torqued.
      2) But it's also possible that your lug nuts and wheels are incompatible. I.E. mismatched taper.
      ________________
      Steve Chryssos
      69LAnd
      well thanks for the help everyone ....ill check on that lug taper mismatch ...hmmm same guys that sold me the wheels sold me the lug nuts ill check over the weekend if they go in all the way
      Rick M.
      hMMMMMMsss....
