      connecticut
      dimensions for a t-56?
      i need the dimensions for a t-56 viper unit .i found most of the specs i needed .but i still need the distance from the input or crankshaft centerline to the lowest part of the trans.
      Central Florida
      Hey Quad
      hope this is what your looking for
      http://www.ddperformance.com/images/t56dia.jpg :icon996:
      Jack
      connecticut
      thanks but i have those ,i'm trying to set the motor low in the chassis ,and i want to check ground clearance ,but i don't have the trans yet. so i need to know how low it hangs below the crankshaft centerline.
      Central Florida
      Guess if I would have read the question better I would have understood what you were looking for . Might want to call D&D and see if they can give you those dimensions, Good Luck
      connecticut
      i called d&d today they said it was 7.5 if anyone else needed to know.
