      Feb 2007
      Dallas, TX
      What could cause a fresh TH400 to do this?
      [IMG]http://i1
      CHICAGO SUBURBS
      A bad build maybe, valve body not right, cluthes and steels installed hight not right, also they must be stacked clutch, steel, clutch, steel. I've seen guys stick anything that would fit in the stack, mostly an old worn clutch or steel to take up space. I also know some trans use application springs that must be upgraded for heavy duty use. Last on a Turbo 400 you need the downshift solenoid hooked up or the line pressure won't rise correctly under throttle. I've seen fairly mild cars not run any and get away with it forever, higher powered cars not last long at all.
