Thread: 86 305 tpi
- Jan 2007
- akron oh
- 9
86 305 tpi
I want to install this motor into a truck. I have all the wires and computer. I would like some input on good=cheap idea's. I looked up a wire set from summit it's 400$. I would like to use the stock set up if possible.
07-25-2008 #2
- Dec 2004
- 203
do you have any specific questions?
07-27-2008 #3Get your hands on the wiring diagram. I know the injectors pull something (power or ground) out of the aldl. The diagram would make the headaches a little less.
08-09-2008 #4
New to Pro-Touring
- Jan 2008
- 12
Use stock computer and loom.Remove all the non engine wiring (AIR . EGR A/C ) leaving only the basic sensors and injectors.
Good reading
http://www.chevythunder.com/fuel%20i....%20pg%20A.htm
http://www.chevythunder.com/fuel%20i....%20pg%20B.htm
http://www.chevythunder.com/fuel%20i....%20pg%20C.htm
