    Results 1 to 9 of 9
      Arlington Heights, IL
      Start motor without trans fluid???
      By the end of today ill be able to fire up my car for the first time in 2 years but i have no drive shaft and cant put any tranny fluid in. Its a T56 six speed. Cacn i start the motor and just make sure to keep the trans in neutral?
      thanks
      Jesse
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      Fontana, CA
      I would advise against it. The input shaft will still be spinning and will need lubrication. Maybe jam the clucth pedal down to keep it from spinning at all.
      Nick R.
      NW Burbs, IL
      If the clutch pedal is not depressed, the input shaft will still spin in the tranny due to clutch engagment.
      I would say no?
      NW Burbs, IL
      Quote Originally Posted by 6'9"Witha69
      You type much faster
      Houston, Tx
      Do you have an old yoke to put in the back of the trany? Will a standard even leak out the back like an automatic will? Fill it up and put a pan under it if it does!
      Springfield, Mo.
      Yes, a standard will leak out of the back if it isnt plugged... ask how i know!!
      your old yoke will probably fit the new trans.... my car came with a powerglide, but the yoke worked fine in my T56.... mine is kind of a hybrid though, i beleive i have a GTO tail housing, i am not sure if my spline count is different than a normal t56?
      1967 Camaro - Done!
      1968 Camaro - Underway
      Alrighty ill just throw in my old yoke then. Thanks guys!
      Springfield, Mo.
      be careful though.... they will spin out if you rev the car too much with only a yoke in the trans and the car in gear
      1967 Camaro - Done!
      Santa Barbara, Ca
      I think if you kept the clutch pedal depressed, it should be fine. As another option, there are those cheap plastic tailshaft plugs they sell at the parts stores in various sizes. I have a set that I use if I plan to have my driveshaft out for any long period of time to prevent any oil leaks.
      Andy
