      Columbia, IL
      Howe ball joint question
      I was installing my Howe tall ball joints and noticed in the instruction sheet that it said to torque to a certain rating and then in bold "not to overtighten". I torqued them to that rating. Now I need to get the cotter pin in. If I loosen the nut up, there is a bit of play. If I were to tighten them up, I would have to add another 20 ft-lbs. Which way should I go?
      Jul 2007
      Tighter is better, if there's play between the nut and the spindle then you'll have problems later and end up buying another b-joint and possibley a spindle.
      If you need another 1/8-1/4 turn to get the cotter pin in, then do it.
      Chris
      Oct 2007
      ridgefield ct
      i've always seen to tighten the nut to line up the pin.
      Farmington Hills, MI
      Quote Originally Posted by megaladon6
      x2 Thats what I do
      JEFF SHORTT
      -IDEAL STEEL
      Dallas TX
      I had a really hard time getting my pins in. Mine were not drilled through the center. So I had to basicly curve the pin to barley get it though. I still had to have one hole just starting to open up while the other side was closing the hole. Not sure if it was a defect or not but ended up with a couple are tigher than I like because I missed my window by lining up visble hole I could see assuming it went straight through.
      Central CA USA
      Quote Originally Posted by dhondagod
      Chris
      X3 that's what I do and have read in the instructions. Backing it off is very bad, can cause a broken stud.
      Feb 2008
      South Carolina
      Torque It !
      I have used the Howe low friction joints in all of my circle track cars. I have never had a failure due to being over torqued. I've had a few friends who have broken them due to crashes and excessive wheel banging.
      Columbia, IL
      Thanks guys! Tight it is.
