    Results 1 to 13 of 13
      Everett, WA
      O2 sensors and ceramic coated headers
      When breaking in ceramic coated headers, I've heard that it buggers up O2 sensors. Any truth to this? And if it's true, how the heck are you supposed to break in the headers without the O2 sensors in place?
      The few, the proud, the crazy... the LT1 owners.
      Aug 2005
      Patterson, NY
      I've never heard of that.
      Everett, WA
      Hmmm...
      Well, I just don't want to f-up my O2 sensors at $100/pop... anybody else?
      Aug 2005
      Patterson, NY
      Well, one thing to keep in mind is that the O2 sensors aren't used on startup and the first few minutes of running.
      I don't know what the break in procedure is for the ceramic coating, so I don't know how long you need to run the engine and how hard.
      If your tune is good you can run without O2 sensors, they should only be correcting any minor changes from the base maps.
      So, you should be able to pull the sensors, break in the headers and then reinstall the sensors.
      Everett, WA
      Yeah, I figured as much. Buy and install O2 bung plugs and heat the bad boy up. Then once it PO's the computer I'll have to re-install the O2s and drag the car down to the parts store to get the code cleared...
      Life could be worse.
      Everett, WA
      Ok, myth busted! I just called Jet-hot, and there is no outgasing or other problems related to their ceramic coating that will cause O2 sensors to fail. Straight plug and play.
      Not to say that other brands of ceramic coatings might be a problem though...
      Apr 2007
      New Jersey
      Jet Hot is not really ceramic coating right so it should be okay.
      Aug 2005
      Hamilton, NJ
      grab some used ones?
      Scott from NJ.
      Vent Windows Forever! ...
      Everett, WA
      Quote Originally Posted by thedugan
      HUH? Um, yeah it is... unless you have some other information that I don't know about.
      Niceville, Florida 32578
      If you break in your engine with the ceramic coated headers, expect the headers to get very dull afterwards. My Jet Hot coated Hedmans sure did.
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
      Jul 2007
      Los Angeles, CA
      Holly says not to break in your motor with their Ceramic coated headers or it voids the warranty. I found a set of beater headers to break in my motor.
      Everett, WA
      Engine is already broken in, so no worries.
      Ontario, Canada
      As I understand it, the ceramic coated headers must be broke in too. You start by letting the engine idle for five minutes then let it cool down completely. Repeat three or four times, increasing idle time with each stage. A couple of short drives with complete cool downs in between and you shouldn't experience dulling of the coating.
      Check with your coating company for specifics.
      Ken
      My other car is a Vega.
