    Results 1 to 12 of 12
      That sounds good. Do I also need a one way valve in the hose from the valley cover to the intake?
      Thanks for the responses.
      Indianapolis, IN
      "Do I also need a one way valve in the hose from the valley cover to the intake?"
      I definitely would on a forced induction car. Just one more way to help keep things in check.
      Mike Norris
      Mike Norris
      Jan 2009
      Cannes, France
      Sorry for jumping in here but I have a similar question.
      My setup is two breathers in the right valvecover and the pcv in the left valvecover connected to vacuum in the lower part in the back of my carb. Will this setup work ok if I install a checkvalve in this pcv line?
      I also run a procharger.
      Thx
      Aug 2008
      Hutto, Texas
      Yes, but I don't use a check valve. The minimal leakage through the PCV valve under boost is insignificant.
      Honey, I don't know how those black marks got on the driveway....
