Results 1 to 1 of 1
Thread: More Vair Love
06-27-2008 #1
More Vair Love
Just thought I would share the progress on this project. A guy named Marv is currently undertaking this challenge over on www.corvaircenter.com
Specs as per Marv
The engine is out of a 1967 Chevelle 327 bored .060", Edelbrock aluminum heads, Summit block hugger headers, Magnaflow stainless steel mufflers, Edelbrock Streetmaster intake manifold with carb flange milled parallel to crankshaft, Chris Craft reverse rotation camshaft and 2 gear drive,custom made harmonic balancer, custom made crankshaft to flexplate adapter, stock point distributor, ChrisCraft AFB Carter four barrel carb, 1965 Chev truck oil pan, spin on oil filter adapter, Hi torque Corvair starter(Clarks) , stock torque convertor, modified trans ( 3 friction plates in forward clutch), trans oil cooler, Summit aluminum radiator, Chris Craft solid brass water pump, custom W/P mount, Edelbrock air cleaner, 3:27 gear with 4 spider conversion, Royal Purple in diff for lube,electric cooling fan out of some kind of Ford, stock 1964 suspension springs all the way around (I might have cut 1 coil I don't remember???) 15"X7 2005 Ford mustang wheels,early Corvette motor mount, redrilled hubs and axles to 5 stud Ford pattern, gutted engine cover, battery relocated to trunk, cooling pipes run inside car under carpet, Hitachi 37Amp alternator,custom thermastat housing, custom engine adapter (327 engine to Corvair automatic bellhousing) ,custom 1/4" steel top plate on differential, I think thats about it??? Marv
marv's brought it a long way from this:
To this Lime Gold 05 mustang color:
Would love to see this car get a Pro-Touring treatment.
Shay
____________
Semper Fortis
