Thread: Steering Flex Coupling -- Help
06-26-2008 #1
I removed the old steering box and flex coupling.
I bolted the new flex coupling to the steering column flange.
I mounted the steering box and fit it in the coupling.
Seems the bolt that holds the flange on the steering column side is rubbing on the housing when the steering column shaft turns... And... The flex coupling is visually not far enough down the steering box input shaft.
Here is my question...
What is the best method to mate these things together? In what order should I put the parts on.
