06-21-2008 #1
- Feb 2008
- NH
- 23
Mcloud Shield, CLUTCH FORK BALL HEIGHT
Have TKO m600 in big block 69 camaro. Clutch pedal was ok up high but seems to be going way past dissengagement. Ball for cluthchfork is adjustable. Have bellhousing out. Can anybody tell me what hight measuring with a straight edge from enginge surface side the ball stud should be at....All factory clutch linkage. Tranny came with all parts in Classic Chevy complete kit. Thanks Kevin
06-21-2008 #2
- Feb 2008
- NH
- 23
Corrections, I believe it's a lakewood housing! The one Classic Chevy recomends
06-27-2008 #3
- Dec 2004
- 203
adjust so fork face is perpendicular to flywheel
Kevin,
You should have gotten a folded 4 page sheet from Classic Chevy labelled "IMPORTANT" on both the top and bottom. On the second page, under "HELPFUL HINTS" for General Motors Application, figure 2 a shows you how it should be set up. In the text below it describes it as well. Basically, use the adjustable ball to adjust for different throwout bearing, clutch, etc thickness, and make sure the fork is angled slightly toward the engine. It's tough to give you a measurement since these things can vary. It's a lot more clear if you can look at the illustration.
If you did not get this sheet, let me know and i will scan it and post it on my web site.
Good luck!
Paul
06-29-2008 #4
- Feb 2008
- NH
- 23
Throught / ballstud adjustment
Paul Thanks for responding. I don't have a four pager?? I do remember seeing an illistration on the clutch rod side needing to be 5-7 degrees forward. I am guessing to the eye this would be slightly moret forward than straight? If all else fails was planning on putting the bellhousing in and with clutch alighnment tool trying to sdjust till it feels right. Yhis may not be a good approach?
Do you know where I could get the correct dial indicater to check the alignment as this tranny is very hard shifting as well. It's mostly me used to a muncie!!!! I am using the blowshield that doesn't require a measurment but givin the work to getthis tranny out with axhaust & on my back I would like to know its right on. Thank You Kevin
06-29-2008 #5
