    Results 1 to 20 of 37
      Lisbon, CT
      98-02 Blazer spindle question
      I am getting ready to purchase a set of 98-02 Blazer spindles with the sealed hubs to run on my 87 Monte Carlo SS. I am wondering if anyone has any information on getting or making a bracket to mount the calipers and 12" rotors from a 2002 Z28. I have seen a lot guys mounting 13" C5 rotors, but my Torq Thrust IIs won't allow it from what I've been told. Hope someone can help.
      Tom Furst
      Once a Marine always a Marine
      82 GMC 2500 4x4 (running project)
      80 Malibu 2 DR (current project)
      04 Dodge Ram 1500 4x4 (daily driver)
      [email protected]
      Eastern Virginia
      What dia wheels you running? 16"?
      Scot
      86 Monte SS
      New York, NY
      If you do decide to go with C5 brakes, I would seriously look at all the costs of a blazer spindle and brake brackets vs. an ATS spindle. Keep in mind you get better geometry and a better hub with the ATS spindle. If you're coming up with similar costs, do the ATS spindle.
      If you do the blazer brakes, then I guess you do save quite a bit.
      Jerome
      Eastern Virginia
      I got mine for $100 for the pair, with hubs. Compared to over $600 for the ATS ones.
      Scot
      86 Monte SS
      Houston,TX
      Not to hijack the thread, but I've got a set of stock like new spindles off of my 02' GMC Sonoma I would let go for cheap... Let me know if your interested
      71' Nova - LY6, T56
      Eastern Virginia
      Quote Originally Posted by NvrDun71
      02 Sonoma spindels are different than 98-02 2WD Blazer spindles.
      Scot
      86 Monte SS
      Houston,TX
      Quote Originally Posted by Samckitt
      damn didn't realize that...learned somethin new. What are the differences?
      71' Nova - LY6, T56
      Eastern Virginia
      I'll look for pics, but the 98-02 "Spindles" use a hub with bearings, a slip on rotor & 2 piston calipers.
      Scot
      86 Monte SS
      Eastern Virginia
      Can't find any good pics on the net, I'll take some pics of mine later.
      Scot
      86 Monte SS
      Cincinnati Ohio
      I would do a 2100 belltech spindle and LS1 rotors and C5 cailpers.
      Im doing S-10 big brake kits, and i have brackets for that.
      And that set up will fit in a 17" Eagle 211(they look just like TT 2's) Not sure if they fit 17" american racing TT 2's.
      Eastern Virginia
      I have the same setup except using C5 calipers, "sadle" brackets & rotors. I felt they fit better than the LS1 ones did. But now I don't remember why.
      Scot
      86 Monte SS
      Eastern Virginia
      My brake setup using C5 Vette calipers & rotors on 98-02 S10 Blazer spindles:
      Scot
      86 Monte SS
      Oct 2007
      Wa
      Are those just stock spindles or did you have to drill anything?
      Eastern Virginia
      Stock spindles. Only thing I did was hit it with a grinder just a "tad" in picture 4 & 5. Pic 4 is on the lower left side where the adapter bracket interferes with it, & in pic 5 where the black bolt needed a little clearance.
      Scot
      86 Monte SS
      Lisbon, CT
      I'm running 17" Torq Thrusts. They were purchased when I it was still running all stock components, so it has the stock backspace. I have a brand new set of calipers for a 2000 Z28 SS. I've been told that these are the same as the C5, only they don't say "CORVETTE" on them.
      Tom Furst
      [email protected]
      Lisbon, CT
      Did you make the bracket in these pics? If so, do you have a drawing with the dimensions? Thats exactly what I've been looking for.
      Tom Furst
      [email protected]
      Oct 2007
      Wa
      Are the C5 Z06 calipers different than the regular C5's?
      Eastern Virginia
      Quote Originally Posted by twfurst
      Yes. I have been trying to find my CAD files and/or drawings of the brackets. But am not having any luck.
      Quote Originally Posted by Memphis
      I don't know. These are almost 13" dia & 1.25" thick.
      Scot
      86 Monte SS
      Nov 2007
      Grove, Oklahoma
      Are these brackets readily available from you?
      Eastern Virginia
      Not at the moment, but if I can find my drawing for them, or redesign them, I can (should) have some made.
      Scot
      86 Monte SS
