    Results 1 to 13 of 13
      Sep 2007
      NOR NV.
      Not having a ball
      I am starting to do the suspension on a 68 Camaro. Dumping the stock front brakes and putting on a QA1 coil over and wilwoods and new sway bar. What I am having trouble with is separating the lower ball joint I lossened the nut and thought that if i gave it a good hit it would pop but it didn't so I got out the pickle fork and buried that and still it holds fast. I ran out of time so now it will sit till Sat. I just thought I would get some ideas. Thanks in advance.
      1968 SS Camaro P/T ---- BD2DBON/PICON PUNCH
      1969 SS Camaro ---- EVERY 1 HAS 69 B.F.D.
      1971 SS Camaro ---- SHOP TRUCK
      1973 SS Camaro P/S ---- GIGGLE GASSER
      1951 Willys Jeep ---- WILLY B. MEAN
      1928 AA Dump Truck ---- FUTURE RAT ROD
      Check it out
      http://www.myspace.com/mrbadrench
      Bad to the Bone painted click below
      https://www.pro-touring.com/forum/sh...ad.php?t=34810
      ITS ALL CUBIC DOLLARS HOW FAST DO YOU WANT TO GO!
      Everett, WA
      Get two 1/2" bolts and a 1/2" tie rod sleeve at any hardware store. Wedge it in between the upper and lower ball joints, and turn one of the bolts to lengthen the whole assembly. It'll press out the lower if you leave the upper castle nut on the upper ball joint. **TIP** drill out a pocket in the head of each bolt to help keep it from falling off the ball joint studs when you're turning the bolts.
      Usually a good whack with a hammer will get 'em loose though.
      The few, the proud, the crazy... the LT1 owners.
      Sep 2007
      Denver
      Marcus at Sc&C carries one of those gizmos already made. I had to use a pickle fork to get old ones off and still had to beat the sh$$ out of it with a BFH for 2 evenings to get it off. Good thing I'm getting new stuff to replace spindle, etc. Next time I use Marcus's device...same as above homemade one. For $20 I get one premade.
      PS don't use pickle unless you plan on replacing ball joints.
      Sep 2007
      Denver
      One last thing, I think my problem and likely yours with the pickle is that it doesn't wedge exactly square on top of the A arm...I finally placed a large screwdriver under the low side of the picle pickled and it popped right off. Upper ones had no problems at all.
      Central CA USA
      Here is a bolt type separator I made, the long nut is a "Coupler nut" I welded a piece of scrap shaft to the other end but you can use two bolts instead. I cut a small dish in each end to keep it centered, plus used a bolt sized to use a 15/16" wrench so I'd have more leverage with the larger wrenches. You may want to get another pickle fork that is thicker if yours is bottoming out.
      they sell tools
      I run the DSE coilover conversion and you have to break the ball joint everytime you adjust shock stiffness or ride height. I was tired of using the BFH to no avail so i went out and bought a Front End Service Kit. It has a tool that does the same job as the ones that are suggested here but is probably a little easier to use and has ball bearings and cradles the spindle without damaging the boot or ball joint.
      I salute all the folks here who made their own but if you are in a hurry run down and buy one of these kits and you'll be set. It takes me about 3 minutes to break this joint.
      Good Luck!
      Jul 2002
      Mesquite, TX
      "Front End Service Kit" - GM tool, or someone else's? How much?
      PA.
      The turnbuckle style tools are actually the style GM designed and recomended back in the day. They stopped making them many years ago, Kent Moore tools took over,then they stopped. We talked Howe Racing into making them again. They quick and easy to use and for $19.90 IMO it`s hardly worth taking the time to make a crude one. http://www.scandc.com/tools.htm Mark SC&C
      Everett, WA
      20 bucks!?! Ha! $3 at a hardware store and no S&H. Take your pick...
      It took me 5 minutes to fab mine up... including drilling a pocket in the bolt heads.
      Sep 2007
      NOR NV.
      Thanks guys for all the great input. I will be up early and at the shop ready to give it a try. I will let you know how it goes. Have a great weekend.
      Check it out
      Henderson,NV
      Quote Originally Posted by 69LT1Nova
      Ya right
      Todd
      Sep 2007
      NOR NV.
      HEAT baby! HEAT was the answer. And the ox/ace torch was only 25ft away. Had my head completely up my keister. Thanks guys for all your prompt advice I do appreciate it. Thanks again.
      Check it out
      PA.
      Spindles are heat treated for proper hardness and ductility so it`s not a great idea to take a torch to them.
      Car $20,000, Trick Suspension and Brake Parts $1500, simple $19 tool to do the job right...priceless. Mark SC&C
