Results 41 to 46 of 46
Thread: S10 M/C Bleeding Tips?
Banned
- Nov 2003
- Maine
- 1,076
great info
so i am still covered with my set-up right?? hydroboost with the c5 master??? as you said i have boost so i can overcome the other issues going on,where as with a manual sytems it needs to be perfect in all aspects??
jake
02-17-2005 #2
- Aug 2004
- 957
I don't know how I looked over this, I didn't see it for some reason, but this is EXACTLY what I have been looking for. Do you have any more pictures of this? The Mustang bolt pattern is a bit different than the Chevy, but it is very most likely easy to modify the part to fit.I will be swapping to C4 front & rear calipers this year and this is what I will be using:
A small update, but important one. I tried the 3/4" M/C on the car yesterday, without success. At first I thought that I had a huge amount of air in the system, because the pedal would go clear to the floor with only moderate force, the pistons in the calipers were clearly reacting, but it was just not good. I tried three different methods to bleed the system, vacuum, pressure, and gravity. No way there is air in the system. I think what is happening is that the stroke of the M/C is insufficient to move enough fluid to overcome the piston retraction of the calipers. I still may be overlooking something, but I don't think so. I can tell you though, I have had it with the C4 stuff. All of this is a PITA, and I still don't get the thicker rotor like I really want in the front.
Brake makeover time in the near future. Very near future. Can you say "Alcon?"
Mark
02-17-2005 #3
