    Results 1 to 12 of 12
      St. Louis, MO
      Tony Huntimer's Camaro Wheels
      I know these are magnesium, are they the ZR1 style?
      Pittsburgh, PA
      Early C5
      john,
      I believe they are 4 front wheels from an early c5. They were an option for them. I believe they are 17x8. I hope Tony will chime in to confirm.
      Shane
      May 2003
      Austin, TX
      his web site www.racehome.com has lots of info on them.
      St. Louis, MO
      Racehome
      Yes, I have read that a couple of times, but the ZR1 question isn't answered there. They look quite similar to the ZR1 wheels, which are more readily available. I just wanted to know if he used these cause they were magnesium, and lighter, or because of the particular shape, if it is unique to that rim.
      May 2000
      Shane did answer your question. They are from a C5. There was no C5 ZR1.
      St. Louis, MO
      Gotcha. I appreciate the help guys.
      john
      Spring, TX
      Here is a link to some for sale:
      http://www.chevyautobodypartstore.co...Y05061U10.html
      Kinda pricey but cool looking. Anyone know how much they weigh?
      William
      San Jose, CA
      Hey John,
      Sorry for not chiming in a few days ago.
      They are 17x8.5" wheels all the way around. The standard C5 wheels are aluminum. The ones I have are a special option magnesium wheel. They are shaped different too. They are pricey, but I've seen a full set of them go for $500 (with tires) on EBAY. So keep your eyes peeled. They are VERY light and really make a difference in overall performance... imagine not having to spin and stop all the extra weight.
      I used them because I got them at a great price. The fact that they are sooo light was just an added bonus.
      Here's a link to some info on the wheels and fitting them:
      http://www.racehome.com/techwheelfit.htm
      Take it easy,
      Tony Huntimer
      RaceHome.com
      @Camaro.Family Camaros
      1986 #IROCdaily - Stock IROC
      Tony, I am curious, since I see you run the Aluminum Wheel Adapters. How long have you been using them, any issues, and how well they've held up?
      San Jose, CA
      Joe,
      Here is a long winded answer.
      At first I thought I was going to have all kinds of problems with excessive wheel bearing wear, so I checked them every few thousand miles. No problems, even when beating the car on highway 9 in the Santa Cruz Mountains on a daily basis.
      I also worried I was going to have one loosen up on me and lose a wheel. I never had an issue. I used the lug nuts with the correct length shanks.
      There are a few companies offering wheel adapters using accorn seat lug nuts to attach the adapter to the hub/rotor assembly. I prefer to use lug nuts with a shank and large washers... as seen in this photo (washers not shown)
      http://www.racehome.com/images/techfebadapteron650.jpg
      I check the torque on the adapter lugs every once in a while. I torque them to 90 ft pounds. The only time I had a lug loosen up on me was when I had a shop put them on, which re-enforcers the reason I like to as much of my own work as possible. I have not used an air gun to install lug nuts since high-school and would NEVER do it again unless I was on a pit crew and the speed of installing a wheel was important. I always use a torque wrench and put anti-seize on my wheel studs.
      I've been using them since 1997 and I have put about 18,000 miles on them.
      I hope that answers your questions,
      Tony Huntimer
      RaceHome.com
      Nov 2002
      Georgetown,TX
      I think those wheels were made by Speedline for GM.
      I've used Vette Brakes & Products billet adapters w/o problems.
