Thread: AF ration vs. HEGO voltage
- May 2003
- St. Charles, Mo
- 424
AF ratio vs. HEGO voltage
I need to modify the VE table in my program, it’s running rich right now. I have an Accel DFI Gen VII system with the HEGO standard O2 sensor. It is not a wideband. The voltage range is 0 to 1.0 volt. The display shows the O2 sensor voltage and not the AF ratio. I believe the range for a standard O2 is 13.5 to 15.5 AF ratio.
I've been tuning it with a friends wideband but he took it back. I change my map scaling to get more resolution in the areas where the engine will see most of it's run time, moderate vacuum between 1400 and 2200 rpm. WOT the engine does great. It is having a few hicups when cruising.
Do any of you know if the AF is inversely proportional to the voltage? It looks like the voltage is higher for the lower AF ratio. When you accelerate, the voltage rises. I would assume the engine is running richer due to extra fuel for acceleration. I believe the voltage should be .47 with an AF of 14.5:1.
At least if I keep the O2 between .05 and .9 I shouldn’t burn up the engine. I’m going to do some more tuning this weekend so if anyone knows the AF ration vs. standard HEGO voltage, I’d appreciate it.
Dennis
