Results 21 to 27 of 27
Thread: 427 Twin Turbo Mid Engine
06-15-2008 #21
- Aug 2005
- 158
specs and cost
The engine starts as a Aluminum Brodix tall deck we punch the cam hole to 55mm and lifter holes to 904 tappet size it has a 4 stroke and 4.125 bore.Cam specs are short it only has 6 degrees of overlap.Were using a special cnc ported spread port brodix cyl head.The intake is our new billet dual injector per cyl which the second injector only comes on during boost so you can run race gas in a seperate cell and utilize the octane on demand feature if the 1100 hp on 91oct is not enough.Were using callies magnum crank oliver billet rods custom Je pistons.We use a stainless oring in the block and run a receiver groove in the head for that.The engine uses a 60 tooth crank trigger ignition and runs a inductive ignition with full lap top programable fuel management unit.This particular engine is running a avaid 4 stage dry sump.The cost of this indentical motor with the dyno wiring,pumps,intercooler the hole sha bang is 45000.00
Originally Posted by monza
06-15-2008 #22
- Mar 2007
- Los Angeles, CA
- 614
A 1750HP Sand Buggy?
Good Lord, I hope there's enough room in the cockpit for that driver's cojones.
06-15-2008 #23
WOW impressive!
No doubt bigvegan!
Originally Posted by bigvegan
Tom, I can't even imagine, can you please post a few pics of the Sand Buggy... is it a professional race team?
I want a ride!Dave
68 Corvair coupe
65 Impala SS
64 Corvair Rampside
62 Corvair Greenbrier
Asst. daily drivers
http://www.sourceboards.com/
06-18-2008 #24
- Aug 2005
- 158
Dyno pics and a video of what it goes in
heres some shots of it on the dyno if you want to see a video of what its going in go to You Tube and put in Tatum Cinders.You will get a kick out of the vid .this motor is going to be sick in this thing
06-18-2008 #25Some vid of that beast on the dyno would be nice!! hint hint
Dave
68 Corvair coupe
65 Impala SS
64 Corvair Rampside
Asst. daily drivers
06-19-2008 #26i want to see video of the thing in the car.
06-20-2008 #27D..D..Ditto!!!
Matt
