    Results 1 to 10 of 10
      Jan 2007
      SOCAL
      blown up today...I think....
      Something has....drove to the coast this morning...nice easy drive...when all of the sudden, it started missing and wanting to die...then....it sounded like a marble was rolling around inside the engine..limped it to a friends house...there was oil all over the ground....and a trail from the direction I drove from......looks to be coming from behind the water pump/timing chain area.....
      took off a valve cover and the oil was a milky color and foam, same with the oil on the dipstick.........
      what to do...what to do...
      Also, the car seemed to be running a little sluggish for a week or so....and there was new sound coming from the area behind the harmonic balancer.....
      any ideas.
      May 2008
      Sounds like a blown head gasket
      mo
      It's bad, will most likely need new bearings it now also, but sounds more like a bearing or something
      Thall shall fear no amount of boost, For thy bottle is with me.......
      Aug 2003
      Sounds like she washed out the bearings to me. Oil is probably on the ground through the dip stick hole from all the water that got in the pan pushing the oil out. Once enough water gets in the pan, it floats the oil and the engine starts lubricationg with water.
      Sorry man, that really sucks!
      Jan 2007
      SOCAL
      Gonna start taking it apart today...see what it is......
      Apr 2007
      Were you monitoring your gauges? Did you see the oil pressure drop? Did the car get hot? Its pretty hard to NUKE a iron 350.
      Huntington Beach, CA
      This post reminds me of a story.
      Back just after high school I blew up my 700R4 for the umpteenth time and was looking to switch to a 400. A friend had one in a car so I went over to his place to test drive it before buying the tranny. We take off and boy does the car a rod knock. Being the salesman he is he wants to show how nice the tranny shifts and he jumps on it about half a block from his house on the way back and it throws the rod and punctures the oil pan.
      So he creates this oil sick as he limps it back to his house. There we are standing in his driveway talking about it. I'm feeling bad for him damaging the motor when 3 younger teenagers go riding by on bicycles. I still don't know it happened exactly but one of the kids hit the oil slick and spun almost a full 360 on his bicycle before flying off. Normally I don't laugh at others misfortune but is was a crack up.
      Ok carry on with your regularly scheduled thread
      Jan 2007
      SOCAL
      the last cyl. wall on the past side is cracked. There is oil and coolant in the valve covers but not in the oil pan.
      So....some people say to hone and resleve and others say it is a boat anchor....
      thoughts..... (this is my first time dealing with a blown engine)
      mo
      start over with a fresh block
      Jan 2007
      SOCAL
      it appears that a screw on the carb that holds the squirter down came off and fell in the intake....bing bing bing...went through the engine....
      I am going to resleave the one cyl. and go for it....I spoke to a bunch of old time racers and engine builderes and they say that it will be fine sleaved.
