    Results 1 to 12 of 12
      Wichita, KS
      Transmission Fluid - Which To Use?
      I have a Muncie 4psd and I am currently using Amsoil in it. I notice when the tranny is cold the gears shift fairly easily. But after I drive the car around for a while shifting gears feels a little more sticky.
      Is this normal for these transmissions? I am using Amsoil which I heard was good fluid to use.
      Your thoughts?
      I build a lot of Muncie's, Borg-Warner T-10's and ST-10's and Nash/Richmond 5&6 speeds...
      I tell my customers if they use synthetic gear lube it VOIDS the warranty...
      Synthetic gear lubes are tooo slippery for the brass/bronze blocker rings to do their job...
      You should only use GL-4 petroleum base gear lube...
      Also if you look at GL-5 petroleum base gear lube and it says its ok to use in posi-trac rear ends,
      it will have a friction modifier that is not good for the blocker ring either... Crash
      So Cal
      What are you using 85/90w?
      1967 Nova SS LSx SOLD!!!
      1967 Nova SS Canadian Ls9 800Hp
      1965 Chevelle 2 Door Wagon
      1965 Malibu SS Convertible
      Pennzoil Gearplus GL-4 80-90... Crash
      Dec 2002
      Lost Wages, Nevada
      Crash nailed the synthetic issues with the available late model 'brass-alloy' sync's that are available in the typical rebuild kits. I will not recommend any synthetic lube in a Sag, Muncie, T-10 derivative or top loader.
      I myself only use a parrifin based straight weight 90 with a suspended moly... for that peticular application.
      Wichita, KS
      Yes 85/90. I think I should probably switch to the Penzoil crash is referring to. Thanks!
      Quote Originally Posted by H8tulooze
      Wichita, KS
      Where can I get GL-4? I can't seem to find it.
      Quote Originally Posted by crash
      I friend of mine owns a speed shop and buys from a Pennzoil Distributor 25 cases of 20-50 racing oil at a time and when I need gear lube I order 3or4 5gal buckets with him and get free shipping... Crash
      Apr 2003
      Central Valley, CA
      Quote Originally Posted by bigboi
      If all else fails your local GM dealership should have GL4 bottles in stock-- mine does.
      The higher sulfur content in the GL-5 additive package, as mentioned, isn't beneficial to the longevity of the syncros.
      1969 Chevelle
      Feb 2007
      USA, TN
      GL4 and GL5 non-synthetic is pretty common at most parts stores. I use Valvoline non-synthetic. I think it is GL-5 with no problems.
      I wonder if Royal Purple will work in these?
      Sep 2001
      Accord, NY
      I had used Redline synth in my Autogear and it was notchy; switched to Amsoil GL-4 and it was much better. After reading this I went to NAPA and bought GL-4 StaLube and it is even smoother shifting. Good thread!
      68 camaro - SOLD
      Jul 2008
      Middletown Ohio
      I have a autogear M21Y and it shifts like crap going into 2nd gear...I am not really happy at all with this tranny. I called and talked to George and he said to run MT-1 spec gear oil..."Cheap stuff" as he called it So I bought Valvoline gear oil MT-1 spec....
      I am about to try TORCO RTF Racing Trans Fluid...Its real thin and wont affect the synchro's....I talked to Torco for like a hour about it on the phone. They felt my Valvoline gear oil was too thick/slick and not letting the synchro's work right.
      If I shift like grandma at low RPM its fine....If I shift like Grandma at high RPM....It grinds like MAD! IF I shift it real hard and firm at high rpm it seems to be OK.
      The Tranny is brand new with about 2000+ miles on it of cruising around... I'm pretty mad about the way it shifts. My buddys all like the feel of the crisp detents and racey feel...But I wont let them drive my car to see how bad it really feels.
      It sounds god awful at times...If the fluid doesnt fix the issue then I will have to have the tranny torn down and repaired. I will have to cross my fingers....Cause this thing has felt bad since day one...I cant afford to be shipping it back to New York either...Or I would have told them to stick the thing you know where...And went out and bought a 5 speed overdrive instead.
