      Boise, ID
      cylinder head id
      Numbers off the heads are 14079261...are these worth using or should I look for something else....block is 010 truck block bored 030, I am looking to go 350-400 hp on a street driven 68 Camaro
      mo
      standard truck head nothing super great
      Thall shall fear no amount of boost, For thy bottle is with me.......
      Feb 2007
      A set od goodwrench crate mmotor heads would be cheap and a good swap or go for the dart SR iron heads instead of spending money on these.
      Southern Indiana
      Heck you cna get some good SR Torqers from world and make 400+.
      Some of my favorites for mild sbc are the 441,487,441X,487X heads.
      Also if you are looking at 350 ci dont pass on Vortec heads.
      Get them from Tri State Cylinder heads 1-800-270-0095
      Not worth rebuild
      These heads are low compression open chamber heads from 1986 truck applications. They only flow so-so, compression limits HP, and the open chamber has no effective quench so these are not worth rebuild. You'll be better off dropping them off as a core and getting yourself some of the other heads mentioned here, either 64 CC closed chambers (like 186 or related castings with double hump) or vorteks.
      It will be nearly impossible to hit your HP goal with these heads on the block you listed as a 355. The block is a good one BTW, with high nickel content--keep it but find some new heads worth your time and money.
