    Results 1 to 9 of 9
      Apr 2007
      New Jersey
      MAP sensor location
      Where are you guys putting your MAP sensor. I want to hide it as best I can. Does it have to be above the plenum? Is distance a problem>
      Doug
      Aug 2005
      Patterson, NY
      I don't think it's location is critical. You do want to use a line large enough to not cause restriction. Height shouldn't make any difference.
      Aug 2001
      Wilton, CA. (Sacramento)
      you want it as close to the vacuum source as possible. A few inches is fine, and it can be hidden wherever, doesn't have to be above the manifold at all. I would avoid putting it inside the vehicle just due to the distance of the line, affects the signal to the map.
      Jody
      Nov 2007
      Afton,Mn
      Probably not a problem on PT cars but you don't want a low spot in the hose.Condensation can build up in the line. I used to work on alot of K-cars.
      Oct 2005
      maple ridge, B.C
      I
      have mine under the throttle body at the back of the manifold
      don't quote me on this but I read on a very reputable site that vaccum hose length(a few feet) has a negligable effect on the signal
      anybody know for sure???
      jason
      1974 charger se modified, 440 727 3:23's, twin turbo t61's,intercooled,custom mpfi,55lb inj, ms1 v3- 2.36,msd6a,msd coil,big rims(20's/22's,4 disk brakes,smoothed, slammed, and scary fast
      http://members.shaw.ca/viper11/
      The MAP vacuum needs to be sourced from the plenum to keep pressure pulsations to a minimum.
      I've seen quite a few vehicles that come from the factory with 2-3 feet or more of vacuum hose to the MAP with no ill effects. I've even seen some with a small inline reservoir to, I assume, dampen pulsations and/or keep fuel vapor from reaching the sensor. In later years, I've seen more and more MAP sensors mounted directly to the manifold with no hose at all.
      Adding length to the hose will slow the MAP sensor's response to actual manifold pressure changes so keeping it as short as possible would be a good thing. That being said, I wouldn't worry too much about having a foot or two of hose as long as it was of suitable diameter and had no kinks or other restrictions.
      67 Camaro, 96 LT1, 4L60E
      Pressure waves travel at the speed of sound, which is about 1100 ft/sec or 1.1 ft/ms. I'm a few years out now, but the company I used to work at sampled the MAP every 15 ms. even at a 5x factor, this still allows for 3ft of vacuum hose. Some of the OEs are actually using the MAP fluctuations to glean more information from the engine, in which case the damping provided by the flexible hose is a problem. Plus, it's just plain cheaper to integrate it. But a few feet should not be a problem.
      Dec 2007
      Springfield,MO
      Run a vacuum line off of the back of the intake somewhere and hook it to the MAP with a hose clamp nice and neat out of the way.
      Apr 2007
      New Jersey
      Great this is what I want to hear.
      I got a spot out of the way, low behind the engine.
      Thanks Guys
