    Results 1 to 9 of 9
      CT
      Need Head bolt length
      Looking for head bolt length for a 2002 LS6 block with LS1 heads..
      Dunwoody, GA
      there are three different lengths. Two are 11mm bolts and the third is a 8mm bolt. Which do you need?
      Trey
      ~ Jon Hammond
      CT
      Can you provide mw with all the lengths and possibly the locations??
      I am trying to figure out the length of the head bolt where the crack in my block is..
      Dallas TX
      Its on the outside so sits one of the long bolts. Why not just pull it out?
      CT
      Much easier to just ask someone that knows than pull it and then the gasket possibly not sealing??
      Simi Valley, CA U.S.A.
      CT
      Thanks Lance,
      Can you tell me where they go??
      Dunwoody, GA
      The little ones goes across the inside of the head under the intake. I'm saying inside if you consider there are three rows starting from the outside edge of the block moving towards the center.
      The shorter big ones go on the ends of the middle row. There are only two of these bolts. The longest ones go everywhere else. The longest one is what bolt you're interested in
      Trey
      ~ Jon Hammond
      CT
      WS6,
      That is what I was figuring.. I will measure the to see where the crack is today.. I just hope it isnt right in the threads..
