      Aug 2006
      austin
      Detroit Speed DSE alternatives
      I'm doing my own minitubbing, and looking at ways to save money. Tubs are done. I have located the following identical parts from the following sources
      Adjustable spring pads (perches): Speedway
      Shock plates and u-bolts: Speedway
      shock cross bar and mounting tabs: Jegs.com or Chassisworks
      offset spring shackles: Speedtech-performance.com
      I had to get the 3" drop springs from DSE (ouch!) (Hotchkiss only sells 2" drop and the Speedway springs aren't rated at any drop).
      I still need the front offset spring hangers. The 2nd gens start out with parallel leafs, so to get maximum clearance, the front mount needs to be moved inboard.
      It appears as though the front spring pockets are really not the pockets at all, but a modification to the frame and sheet metal to offset the factory pocket a couple inches inboard.
      Does anyone have any detailed photos or drawings of these pockets? It appears as though these may be made "in-house", but I'll bet some circle track guys have done this before.
      Any help?
      thanks
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
      May 2002
      Northern California
      I was going to say, save the trouble and make a link kit for it.
      Theres a bunch of routes you can go for the fronts. I suggest get everything mocked up and see where you need to go.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      St. Pete FL
      fellow 2nd gen'er subscribing...
      HELP!!!
