      Aug 2011
      Connecticut
      The Nemesis (Fox Body Mustang)
      So my fiance got bit by the bug, Unfortunately it was with a 4cyl 4spd drop top fox body mustang!
      Her father has donated his absolutely clean and rust free 1990 Mustang LX convertible for the build. I am donating a gen IV aluminum 5.3 with 243 heads for the build.
      The goals are to build her a street strip car, Not a ton of power but good enough for her to autox and drag race. Full LS swap and probably a 4L60E since she isn't keen on the manual set-up. SN95 5-lug swap, decent wheels and tires and a tubular k-member. I will also adapt SN95 coilovers from BC Racing into the car, maybe down the road do an IRS set-up in it.
      For now the car will be know as "The Nemesis" My build will continue on my 67' Firebird and my 64' Rambler, busy busy household
      More updates will come in once we get the car from Ohio to Connecticut. For now, here are some pictures.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Mar 2014
      Mesa, AZ
      Cool, another Fox!
      When you get around to fitting the BC coilovers be sure to show how you do it. I've looked at their stuff after watching lots of Hoonigan videos, I wouldn't be opposed to running them in the future.
      Nelson
      Jan 2016
      Chino Valley, AZ
      welcome fellow fox builder!
      i would highly, HIGHLY recommend full-length subframe connectors to your list. i'd even consider them a must-have. foxes are wet noodles, verts are the worst.
      IMHO i would only do the tubular k-member if required for your swap. bang for your buck, adressing the 4-link rear and converting it to some sort of phb or watts + torque arm/3-link should be high priority. really changes the characteristics of the car for the better.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Sep 2016
      Quote Originally Posted by frink84 View Post
      You don't even need to swap out the k member for an ls swap now, Holley has that covered.
      https://www.holley.com/products/ls_p...ap_components/
      Should be a fun little car!
      1993 Fox Body...its in the works
      https://www.pro-touring.com/threads/...72#post1249772
      1972 Nova...OUT OF THE BARN!!!!! Build coming soon!
      IG:@kdmerritt5 for more
      Aug 2011
      Connecticut
      Subframe connectors were absolutely on the list. I was looking into swapping the solid rear out for an IRS system. But it sounds like she is more interested in a street cruiser and occasional bully on the highways or strip
      - - - Updated - - -
      Quote Originally Posted by Merritt5 View Post
      good call, thank you!
      New updated thread
