Results 1 to 17 of 17
Thread: Brake woes
06-03-2008 #1
Brake woes
I originally posted brakes stay locked up, where I was experiencing my brakes locking up after driving for a while.
I have disc all the way around on my 69 camaro 13" front 12" rear. I set up the brakes with a CCP package and ran them as a manual unit until just recently adding a booster. Under manual the brakes were fine, not great but not bad. I didn't like the peddle effort so I added a booster. The first booster provided great peddle feel and great braking. The problem was when you apply the peddle it would click as if the rod was caught on something, and after driving a while the brakes were locking up. I decided to just replace the booster.
The new booster now has a hard peddle and terrible braking distance. I measured the boost and it is 10-12" at idle. CCP says i need at least 18" at idle to run the booster. When measuring the rod/master/distance... I caused the center bore on the master to come out. I pushed it back in and reinstalled the C-clip, CCP doesn't think it would have been damaged.
My question/problem; the master leaked from the top the moment I installed it, now I am not 100% sure if there is a leak from the top or from the center bore and I hate the breaks. Am I running enough vacuum to use the booster? Is there a better or newer style master that I can use? I like the plastic reservoir style which seems to seal better.
Tobin/Kore I have read a few of your replies to similar issues and would appreciate your input. You suggested a master from an 98-02 camaro/TA for someone else; would this be a good option for my set up? Anyone with a suggestion is welcomed to reply.
