      harmonic damper--'86 on '75 block?
      I'm assembling my car for race day and tossed the old harmonic damper because the tdc was no longer at tdc. It's a sbc 350, 1975 block in my '68 camaro. The used harmonic damper i picked up has "302 86" and "H2222" on it. I think it's from an '86 block (one piece rear main seal). Since the '86 and later blocks use internally balanced cranks, is this damper not interchangeable? I looked in summit, they do not seem to list different dampers for '86 and later blocks...
      Have others run these on older blocks, or do i need to go pick up another used one? Don't want to spring on a new damper because at the end of our season i'm switching over to a 400 block, so no sense investing in a new damper when i know it'll be replaced soon.
      Thanks!
      with the exception of the 400, all production small block dampers from 55-98 are functionally interchangeable. the only differences you need to worry about are the overall diameter and TDC line location.
      the damper that's on the new ZZ4 and fast burn crate motors (late model 1 piece rear seal) is the service replacement part for the 69 302.
      the other end of the engine, however, is a different story. on the one piece seal engines, there is a counterweight on the flywheel/flexplate and the bolt pattern is different than the old parts so you can't accidentally bolt on the wrong part.
      Sep 2002
      San Jose, CA
      Ah -
      86 and newer -piece rear main engines are external balance. The harmonic balancers are not interchangeable with the earlier engines
      Just call me Brett
      Balancers are the same witht the exceptions that novaderrik posted above. The flywheel balance was changed due to the one piece seal design, not the dampers.
      John
