      Aug 2001
      Connecticut
      qa1 coilover rod end failures?
      Hi- curious if anyone else has had issues with the plastic and metal 'heim' type inserts that come on the qa-1 coilovers? (not the rubber/urethane ones); I just changed my front coilovers from an older set of pro's to the qa-1 to match the rears on my car, took it to one autocross and back home and both front shocks had the plastic litterally blown apart- even pushed out the snap rings. (I'll post pics tommorow) I've emailed qa1, but haven't heard back, now I'm off the road for another weekend...
      I guess if you're not breaking anything you aren't pushing it hard enough, but this is a bit much.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Aug 2001
      Connecticut
      pic attached
      2006 Corvette Z06
      Oregon
      Do you have a picture of it installed and/or articulated? It almost looks like it exceeded the range of motion for that design of spherical bearing and the standoffs crushed the outer portion of the liner.
      Tobin
      KORE3
      It's what I does.
      Auburn, WA
      If they fit, I suggest using FK inserts. They're for 1.000" diameter bores.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Aug 2001
      Connecticut
      I've re-ordered the all-steel versions; but I figure it might be worth keeping an eye on if anyone else is using these. I'll upload a suspension pic later, but there is a pic with the old shock in my pt garage. Definately no bind or range of motion problem, I dry fit it without the springs to be sure. -Dan
      2006 Corvette Z06
      Thats good to know scince I'm ordering shocks soon
      Feb 2008
      glad i got the bushing ends for mine, but make sure there isnt any binding anywhere
