    Results 1 to 11 of 11
      Hedman 65019 Header Pic's
      Hi guys,
      Does anyone have a picture of the mentioned headers? These are equal length, 1 3/4" primary tube deals, and I am most interested in the driver's side. I think most folks run the Elite's, this is NOT them, and I am having a really hard time finding any specific information on them.
      A pic of a small block first gen Hooker Super Comp in 1 3/4" would be cool too, if available.
      Muchos Gracias,
      Mark
      westchester county new york
      Ttt
      Central Valley Ca.
      I have Hooker Supercomp 1 7/8" on my sm 400 in my '69 Camaro. I have never liked them. They hang to low. I think they are a little big as well. I'm looking for some 1 3/4" now. I will be looking for some custom header now, because I have a set of Brodix spread port heads for it now.
      CHICAGO SUBURBS
      My buddies car I built has these on it. What part, or where, do you want to see? They fit great, no clearance issues. 1968 Camaro, 383, Edelbrock heads. They tuck up pretty tight too. FRANK
      Pics of driver and passenger side engine compartment and a few shots to show ground clearance please.
      CHICAGO SUBURBS
      This is the left side header. I can't upload any more pics. The driver side dose not hit anything at all, and is tucked up tighter that this one. You can just see where the control arm almost hits one tube. I tried to push on the tube with a large flat bar, causing a slight crease. This was enough to create aroung 3/8 clearance. Also if I took shims out of the arm or had non-stock ones it would clear no problem. FRANK
      CHICAGO SUBURBS
      Maybe it'll work now.
      Sep 2001
      Accord, NY
      Does the #1 pipe go in front of the 3 and 5 or over? I have the 65003's but could use more clearance on the steering box.
      68 camaro - SOLD
      CHICAGO SUBURBS
      The two center pipes on the driver side, go under 1. It is close to the steering box at one point but does not touch. This car has the '69 ss350-302 frame-stands.
      Sep 2001
      Accord, NY
      Thanks. I do too. What motor mounts? It's tight with the energy suspension items!
      68 camaro - SOLD
      CHICAGO SUBURBS
      The mounts are Energy poly mounts also. I will say these are the best fitting large tube headers, I've ever installed. No more supercomps for me.
