    Thread: Rusted body
      Rusted body
      I have a 1941 power wagon that hassn't been painted for years and has a rusted body. I hit it with 80grit on my DA and it comes off but what do I do after I sand the body? It has a little pitting so can I just use a blocking primer and the seal and paint?
      Mike
      Wichita, KS
      well your not being to specific here. but basically sand the pitted areas well and make sure the areas inside the pits are fresh metal, wax and grease remover, then use GOOD QUALITY EPOXY PRIMER.
      67 GTO, LS2, T56
      WILWOOD, FORGELINE, RIDETECH
      May 2008
      Northern California
      Surface corrosion or deeply pitted rust areas all need to be chemically treated. I would suggest you go to your local automotive paint supplier and inquire what they have available for you to use. You might consider speaking with someone at a shop that addresses alot of rust issues. There are so many treatments for rust so it would be to your advantage to make your inquiries and then make your decision.
      Only after you've treated the rust concerns should you follow up as goatman said, to apply a good DTM (direct to metal) epoxy primer as your foundation prior to doing any filler work.
      I would also suggest you acquire all the product tech sheets for any of the chemicals you plan on using to address your rust issues.
      Good luck!
