    Results 21 to 40 of 47
    1. #21
      England
      Judt thought if the the water pump is not for a LT1 then the water flow is going the wrong way ,but reversing the pump will not cure it as the blades will be wrong for the flow. What is the pumps part number and whats the make.
    2. #22
      livermore ca
      its a csr part number:CSI-901LT1
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
    3. #23
      England
      Ive been to there web site and they have a tech number, i would give them a ring as it could be something simple.
    4. #24
      Santa Barbara, Ca
      I was thinking the same thing about reversing the pump wires to make it spin backwards, but I think you are correct; The impeller is probably only designed to run in one direction.
      If you got a standard rotation electric pump, that could very well be the problem. I'm not really sure what effect having a standard flow pump would have on a motor that has a reverse-flow cooling system, but it cannot be good. Maybe the coolant is trying to climb up the radiator instead of down, causing poor flow and high temps.
      Just a thought, but I told you before that I don't know much about LT1 motors in particular.
      Andy
    5. #25
      livermore ca
      i have the right pump for the car. i had it started yesterday and the upper rad hose gets hotter than the bottom. also tomorrow im going to try and lower the rad. with the lt1 motors you have to run an expantion tank and it has to be higher then the rad. it is higher right now but im going to lower the rad a little bit more anyways. they say if its not high enough you can get air pockets. i really dont think i have any air pockets becuase i can hear the pump pumping the water and see it moving when i take the expantion tank cap off.
      65ss chevelle
      63ss nova
      3:73
    6. #26
      Dec 2007
      take the thermostat out completely and try it and put the thermostat in some water with a thermometer and heat it up to see when it opens. Also what about your fan shroud...some pictures might be helpful
    7. #27
      livermore ca
      i dont have a shroud on the car. i think i might order one tomorrow from summit. also if i have my fan on the front of the rad(out side of the engine bay) should it be pulling or pushing air?
      Quote Originally Posted by avewhtboy
      65ss chevelle
      63ss nova
      3:73
    8. #28
      Marshall , MO
      If it is outside the engine compartment IE behind the grill but in front of the radiator it should be pushing. That is not the most efficient way for the fan to be mounted. If you have the room move it to the other side of the radiator pulling air.
      Brad Shepard
      69 Malibu
      Marshall, MO
    9. #29
      livermore ca
      things are tight on the other side due to the water pump. i know for a fact that i would not be able to add a shroud if i did move the fan to the other side.
      65ss chevelle
      63ss nova
      3:73
    10. #30
      Santa Barbara, Ca
      I don't know the exact numbers, but you lose a lot of cooling efficiency by using a pusher fan (mounted on front of radiator). They will also lose 25% of their flow if a fan that is designed to be a puller is used as a pusher as the blades are usually optimized to spin one direction. You also don't have a shroud you say, which makes the situation worse. I'd like to know what size and model fan you are running. Pics would be nice.
      I'd also like to know what the thing runs at @ 65 mph +. That should eliminate the fan from the mix.
      Andy
    11. #31
      livermore ca
      65ss chevelle
      63ss nova
      3:73
    12. #32
      Aug 2001
      How many inches from the rad to the water pump ? You need a good fan- shroud combo. What is the timing set at ? Not enough advance will make it run hot.
    13. #33
      England
      When you first stat the engine ,keep it ticking over ,and keep placing hand on rad to see if the water is flowing round and not just heat trasfering ,Watch your hands.
    14. #34
      livermore ca
      Quote Originally Posted by paul67
      cant i just turn the pump on? becuase its an eletric pump so turning the motor over would not turn the pump on?
      65ss chevelle
      63ss nova
      3:73
    15. #35
      livermore ca
      i dunno what the timing is set at pcmforless did all the tuning so i would have to call them. as for how many in away i would have to look after my class this after noon.
      Quote Originally Posted by Charley Lillard
      65ss chevelle
      63ss nova
      3:73
    16. #36
      England
      Ok turn motor on then turn pump on , see what happens when putting hand around rad . Do you run engine then turn pump on when engine reaches a certain temp then turn the fan on,
    17. #37
      livermore ca
      no i turn the pump on when i start the motor and the fans come on when the car is started.
      65ss chevelle
      63ss nova
      3:73
    18. #38
      England
      I'm running the same engine as you i will go and measure my rad back in a bit .
    19. #39
      England
      Ok
      Alloy rad core dimensions 23" wide,18" high,3" deep.
      Tanks LH side 3"x3"x18" RH side 3 1/2" x3"x18"
      Fan 16" puller
      Lower rad hose which has the thermostate goes to the RH side
      Upper rad hose goes to the left hand side.
      In front of rad is an A?C consensor ,the rear a trans cooler.
      Catch can is the same level as top of rad.
      Hope this is of some help.
    20. #40
      livermore ca
      ok well i am going to pick and pull (bro blew the rearend in his truck) when i get back ill pull the t-stat and make sure it is working the right way, and try seeing if i can move the fan on the back side and i will get back to you guys. thanks a ton for all the help guys. ill be back later with some info
      65ss chevelle
      63ss nova
      3:73
