Thread: 64 Novas
05-23-2008 #1
- Sep 2004
- VA
- 281
64 Novas
I've done a little looking around but hadn't turned up much in the way of early novas. Most of what I find is for i think its the second gen nova. (66 to 72? or 68 to 72 whatever)
Anyway, whats available out there for the early novas as far as handling /mini tubs.
05-23-2008 #2TCI Fatman Art Morrison. ALston Chassisworks, etc..
THere are a ton of bult in clips, bolt in 4 links, etc...
Most chevy geared magizines are full of ads for them.1971 Camaro 427 in waiting
1988 C1500 Daily Driver
05-23-2008 #3A lot of stuff is available for the 1st gens. No mini tub kits though.
http://www.classicperform.com/'50 Ford Coupe (project)
'64 Chevy NOVA SS
05-23-2008 #4
- Sep 2004
- VA
- 281
thanks for the links. I've seen a couple pics of early ones on this board, but hadn't found out what they were using for suspension or what would work/cram in the fender wells.
05-23-2008 #5
- Mar 2006
- escanaba, michigan
- 202
the nova i had(63 s.s. convert.) had a full frame with a heidt's front suspension. i took the coil-overs out and bolted in shockwaves from a.r.t.
the rear suspension was tubbed with a narrowed currie 9 inch rear end, ladder bars and shockwaves. it had 18x8 wheels in the front and 20x10 wheels in the rear. i was able to retain the back seat and the wheels tucked up in the fenders nicely. with no air in the system the rockers were about 4 1/2 - 5 inches off the ground.
i did have some aftermarket inner fenders for the front so i do not know if my setup would have worked with the stock inner fenders. i hope this helps. there are alot of companies making parts for the novas now. alot also depends on your budget as well. i hope this helps.
