      May 2008
      Sensor Question??
      Wondering if there is a sensor available,,,that would be able to trigger an electric fan,,,and also be the sending unit for a water temp gauge???
      Apr 2008
      Oceanside, CA
      Sure. I'm using the sender from my Classic Instruments gauge to run my Dakota Digital controller. I'm pretty sure the standard 33 to 240 ohm senders are capable of working with alot of controllers.
      If you're not using a controller then you'll have to use a seperate temp switch.
      Len
      67 Camaro SS-350 Ragtop
      406/200r4
