      65 fastback motor mounts Help !!
      Well I have decided to keep my 65 Fastback... Putting the 302 motor and tranny in it and I have the correct frame mounts but the motor mounts I got dont seem like they are the right ones. First off, they do not rest on the tab at the bottom of the Frame mount. Secondly if I line up the holes between the frame mount and the motor mount they will sit about 1 1/2 inches above the tab on the bottom of the frame mount.
      This is not the problem that concerns me though. The problem is both mounts are exactly the same. Every website I check says that these are the right mounts and that they are interchangable per side but if I place the mounts on the frame mounts with the bolt through them. There is about an 1-1 1/2 inch difference between them. I know the mounts on the block are the same distance from each other. Is this just an optical illusion or am I missing something here. Just to clarify, the mount on the drivers side sits about 1 1-1/2 inches further back than the passenger side mount!! The part number I have is from Anchor and it is #2287. I will try to send a picture later if that would help better explain it but would really like some input here if you have any. The tab on one side of both motor mounts is longer than the other side so if they are truly interchangeable then one side would have the longer tab and one side would have the shorter one.....
      Mark
      TOOFUN
      Apr 2008
      Ohio
      There should be a right and left side on your motor mounts. If you put them in backwards it'll move the engine out of alignment (~1" forward) IIRC. (Has happened on a few Fox body owners) ;)
      I couldn't find #2287 for your application.
      Most of the 60's 289/302/351 call for #2257 (same part # for both sides...)
      For a '65 289, Anchor shows two different mounts (L/R) for the pre Mar/66 cars.
      ANCHOR 2220 [Engine Mount] Front Left; Before: 3/66 *
      ANCHOR 2221 [Engine Mount] Front Right; Before: 3/66 *
      Post up photos of the offending mounts and I'll see if I can ID them.
      Hope that helps.
      -Adam
      Well here is what Mustangs Unlimited sent me. Part # 2287 I think they sent me the wrong mounts even AFTER I SENT THEM PICTURES OF MY FRAME MOUNTS!!! Anyways, when I put them face to face like you see in this picture you can see that they do not line up so not only did they send me the wrong mounts, they sent me two of the same side of the wrong mounts!! From what everyone else can tell me from my picture I have LATE 66 Frame MOUNTS, which would use the 2257 style Motor mounts. Would like to have someone confirm this for me if they could. Thanks for answering my question on this I really appreciate it!!
      Mark
      TOOFUN
      Apr 2008
      Ohio
      Those DO look like the 66-70 v8 engine mounts... Those years call for the same mount for both sides. The early models called for two different mounts.
      Do the mounts fit on the frames without the engine? You could bolt the mounts in place on the frame, then lower the engine down and see which side is off...
      You might also want to check out corral.net or allfordmustangs.com
      I'll look around for some options...
      You might need something similar to these:
      http://www.jegs.com/i/Prothane/311/6-503-BL/10002/-1
      See how the one ear is longer than the other, but they're both on the same end of the motor?
      Well I never would have believed it but the motor mounts are correct.... Seems that for early 302 motors the block motor mount bolt holes ARE STAGGERED!! I never would have believed it but saw this picture on the net and confirmed it with my motor. To be honest they look like they are in the same place on both sides but the cyliders on a ford are staggered unlike the chevys that are symetrical....UNBELIEVABLE......
      Mark
      TOOFUN
      Another trick, if it doesn't want to sit down on the frame mounts, is to unbolt the export and monte carlo bar, the put pressure on the cross member under the engine with a floor jack until the bolts line up... Mustangs sag every which way.
