      Eastern Virginia
      Sphericle bearings...?
      http://www.hulu.com/watch/15077/car-...in#x-4,vclip,1
      Scot
      86 Monte SS
      Oct 2007
      ridgefield ct
      i read about that concept a few years ago. IIRC as carbon builds up on them it actually causes them to seal better! it's a cool design concept. i'm kinda surprised that no OEM has tried it.
      OC CA
      Hmmm.... Interesting.
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      Eastern Virginia
      I bet it is expensive to get the valves made from ceramic to those tolerances.
      Scot
      86 Monte SS
      north central Iowa
      Quote Originally Posted by megaladon6
      according to my field service engineer at bmw.....bmw has been testing a similar design, apparently they were testing it for use in F1 but I havent seen or heard anything else about it since then. BMW i guess is also testing a camless engine with electric solenoids to actuate the valves.
