      Axle Tube to Center leak
      What is the best way to seal the joint where the axle tube is pressed into the center section on a 8.25" Chevy rear end. There is a little seepage / bleeding around the tube and I want to seal it while I am refinishing the entire rear end. I do not have a welder. Thanks for any ideas.
      JEFF
      JEFF
      1968 Camaro RS/SS - "BLUE"
      www.fquick.com/jmd68rsss
      May 2002
      Northern California
      Best way is to weld but I've seen guys heat the area up with a propane torch (not much 120-130 degrees??) pull the flame away and squirt a few drops of green lock tite into the gap. Enough to get down in the cracks. I've never done it but they say it works.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Mr Quick
      Thanks for the reply. I am going to try this.
      JEFF
      JEFF
