      Loganville, GA
      Oil dipstick vs pan
      On a 72 400 sbc, I have a Moroso road race oil pan, listed at 6 quart capacity not including the filter. I also have new GM dipstick, upper and lower tube for the same engine. I put 6 quarts in the pan (5 days ago) and checked the dipstick and it barely registers. It is showing approx 2 quarts low, guestimating by the marks on it. The dipstick is 19" long (not including handle), with the full mark at 17" and the add at 18". The dipstick is a service replacement with the wonderful yellow t-handle (I guess it's faster). The upper tube is 6" long from the top to the block. I was wondering if the measurements match anyones dipstick. The only choices I have are to add more oil (not ideal) or shorten the tube till it matches the oil level. Just looking for some ideas or advice, before I start cutting stuff.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Sep 2001
      Accord, NY
      I would, and did for my situation, take a scribe and mark a new 'full' line.
      68 camaro - SOLD
      Chicago suburbs
      Did you run your motor? The filter (if installed dry) will hold about a quart, which would bring your total to 7 (6 in pan, 1 in filter). I also run a Moroso pan with a bigger sump and I use the "add" mark on my stock style dipstick as my full mark. In my opinion, as long as you have the capacity, running "low" on the stick will just help avoid windage losses. The farther away you keep that oil from the crank the better.
      By the way- did you check your oil pickup to pan clearance? I had 1/2" with the "matching" pan and pickup.
      Loganville, GA
      I had 6 quarts in the pan to see where the level was. I hadn't run the motor yet. I ended up cutting 1" off the upper tube, which put the "add" mark as the full mark. I was checking GM parts books and they listed cutting the upper tube depending on the application, so I measure several times and then cut once. Oil pickup clearance was checked when the motor was assembled (I helped while it was being built, helps when your machinist is a good friend). I can't remember the exact clearance since it was 4+ years ago. On a side note, it did run today, quite well. The only issue is a leaky rear main, not alot but more than I care for.
      1975 MGB Roadster
      2003 GSX750F Katana
