    Results 1 to 10 of 10
      Oct 2006
      Norway
      Brake line flaring
      As I understand there is diffrent flare types old one and metric/ bubble flare. Anuone have pics or tell the diffrence. BTW is the S10 master having old or new flares ?
      Olav
      Oregon
      S10 master cylinder from the 1980's are all inverted flares at the ports IIRC. You didn't specify a year, but I assume you must be using the stepped bore unit for your C5/LS1 upgrade?
      Bubble flares are essentially an inverted flare that hasn't had the bubble "inverted" onto itself.
      I'll see if I can't turn up a good link or picture with a schematic showing the differences.
      Tobin
      KORE3
      It's what I does.
      Here is a picture of your basic 45 degree double flare:
      Here we go:
      Oct 2006
      Norway
      Oct 2006
      Norway
      Thank you!
      Olav
      Are you using the quick take up S10 MC? Will you have manual or power brakes?
      Oct 2006
      Norway
      I have a Cardone 10-1905 have machined it to fit Hydraboost. I'm little worried if this is a power or manual master. I was told it is a power unit. Anyone have a cross reference list. The GM Delco power is # 18M310
      Olav
      Oregon
      Quote Originally Posted by Olav
      Olav
      The manual MC is an ACD #18M309 and has 24mm x 31.75mm stepped bores.
      The power MC is an ACD #18M310 and has 24mm x 34mm stepped bores.
      My experience is with the manual unit, but I would think that the power unit in a manual application would just result in a slightly higher pedal due to the larger primary bore, otherwise braking effort should be equivalent due to the equal secondary bores.
      Tobin
      KORE3
      It's what I does.
      Tobin,
      I actually went from the manual S10 MC on my GTO to the Malibu manual MC that you recommended in another thread. Check out my build thread:
      https://www.pro-touring.com/forum/sh...003#post369003
      I am very pleased with the pressure that is being generate at the caliper and with the effort. I think it will work great.
