      Wichita, KS
      Dual Fan Temp Sensor Wiring Diagram Needed
      I have a Ron Davis Radiator w/ Dual Electric Fans. The fans are currently wired to a toggle switch. When the toggle switch is ON the fans will run when the car is running.
      With the fans running all the time my temp is at 160. I would like the car to run at 180 so I think I need to install a temp sensor to kick the fans on at 180.
      Does anyone have a wiring diagram showing how to do this?
      TuoCo, CA
      Steve
      Check it Out Here
      TuoCo, CA
      oh yeah, you'll want this for the second fan....
      http://etxiow.accpaconline.com/itemd...01358&item=FRH
      and if you want to get all fancy you'll want a SPAL pwm Fan Controller
      Steve
      Check it Out Here
      Wichita, KS
      Thanks man!
