    Results 1 to 11 of 11
      NJ
      spal pwm contoller issue.. solid red light
      Controller's about 6 months old i'd guess and has worked great until yesterday... was data logging and temps started raising and raising...
      Pulled over and checked the fuse which was fine, checked the ground and associated wiring to controller and fan and all was fine. Started her up and the fan kicked on like nothing ever happened.
      Today heading home from work the temps started to rise again... pulled over and checked.. same deal except this time the fan didn't come back on and I get a solid red light on the controller.
      I just checked all the wiring now that im home and can't find any thing wrong with the wiring or temp sensor wiring. Thinking the controller is fried or something. I checked the manual and it doesn't say anything about a solid red light so was hoping someone here could clue me in it would be much appreciated.
      thanks
      Ryan
      - Ryan
      91 Syclone
      01 Kawasaki zx12-r (dyno'd 198rwhp)
      88 Mustang lx
      87 Buick GN - sold
      90 Mustang lx - sold
      NJ
      well since no one replied I figured i'd update the post incase someone else has the same problem in the future
      The controller's getting power but not putting any to the efan... contacted SPAL's tech support and they suggested applying 12v to the ac wire and if the efan doesn't power on it's a bad controller.. only other suggestions were to see if there was any water underneigh where the push buttons are.. sometimes that was an issue and double check my temp settings set on the controller.. My efan doesn't get any power from the controller so im going to be contacting Spal again and seeing what I can do to get a replacement controller since it's only about 7 months old.. anyways hope this helps someone in the future
      Ryan
      - Ryan
      91 Syclone
      88 Mustang lx
      87 Buick GN - sold
      Jul 2001
      Calgary, AB
      Ryan,
      I understand that there were some issues with SPAL controllers (last year) and they were anticipating a fresh production run in February of this year that supposedly would not have the same issues. Sounds like you might have one of the older controllers. I believe that SPAL will take care of you without question.
      Good luck,
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      NJ
      James,
      Thanks for the info, I've never heard a bad thing about these controllers until what you just said.. Im still waiting to hear back from SPAL but when I spoke with the on Friday about this they seemed like good people so im not worried especially since the controller's only 7 or 8 months old.
      - Ryan
      91 Syclone
      88 Mustang lx
      87 Buick GN - sold
      The guys at Spal are great to work with-they'll make it right with you. I deal with Mark quite a bit and last time I spoke with him, they were set to release their new controller design in early-mid June, so we'll see how well it does. Like anything, it takes field research of all kinds to perfect anything, it's cool they take their controllers seriously. The solid red light would indicate to me that the high speed circuit should be tripped allowing full power to fan. Sounds like a faulty controller.
      [email protected]
      TuoCo, CA
      how many people are running these controllers w.o issue?
      I have one to install but I'm worried about it now.
      I'm going to be doing a 2,000 mile roadtrip this summer. I'm thinking about leaving the spal controller off until I get back.
      I'd like to have it on.
      Do these things fail on startup or do they fail after time?
      Steve
      Check it Out Here
      Jan 2002
      Crockett, Texas
      I've been using one for about 2 years now, it's fine.
      It's a kind of a pain to program, but after it's set, it stays.
      By the way, I'm using a switch so I can override the controller just in case.
      Don 67 Camaro RS/SS Texas
      Illinois
      I got one last september and install it and every thing worked fine untill Jan and I came out to the garage to start the car the car was dead, put charger on and controler came on and fan runs all the time will not shut off so I took the fuse out.
      I called spal and they said it was the controler and to take it back to the dealer I got it from. I can not find the name dealer or my copy of the bill to get a phone number so not sure what I am going to do?
      Rich Bryant
      1965 Chevy Nova SS
      331 ci small block Street Challenge Air Ride
      CPP upper & lower control arms
      TKO 600 5 speed
      Shotts Americana's and Kumho tires
      Disc break upgrade
      NJ
      I don't what you could do Rich without knowing who you bought it from and when.. I was told by the SPAL tech guys that they you must return your unit to the retailer you purchased it from in order to get a replacement but I just found out from the place I got mine from that these controllers are on a nation wide back order.. and SPAL is redesigning them anyway. They'll be avalible in a month or so is what I was told and I can't wait that long so I will be sending my unit back for a refund.
      no only if I could get my hands on one of those dc controllers i'd be happy
      - Ryan
      91 Syclone
      88 Mustang lx
      87 Buick GN - sold
      I have to say that the DC Controls units were nice as far as reliability-I've used them before too. As for the Spal units, I am waiting for the new design to come out so I can see how they perform. I should be one of the first to get one and I have a couple of builds in the shop which will need them by the time they come out so they can go through a "trial" run if you will tto see if they are any bugs to work out. The problemwith any fan controller is that a lot of people are running HO factory style fans which draw a lot of current-that's also why they way outperform aftermarket fans....and I am referring to Mark VIII, Taurus, T-Bird and LS1 fan designs. Spal new design is an attempt to run these types of fans so they should be able to handle any fan. We"ll have to see. -Jabin
      [email protected]
      NJ
      Jabin,
      Please post up your results with the new model when you can because that's exactly what im running a factory 16" bosch 2 speed fan from a volvo that's rated at 3000cfm so it does pull a bunch of amps during initial turn on which seems to be my problem and hopefully I can figured out how to wire up two relays and a circuit breaker to get them going again until the new units have been out for awhile.
      I'd really like to go the dccontrols route but I don't think he's making them any more and there was such a long wait time I need to get this sorted out this week
      - Ryan
      91 Syclone
      88 Mustang lx
      87 Buick GN - sold
