    Results 1 to 20 of 33
      Feb 2008
      los angeles
      Why doesn't this thing steer better?
      I have just replaced all the suspension on my 69 camaro. New CCP upper and lower control arms, QA1 coil overs, CCP 2" drop spindles, Hotchkis 1 1/8 front sway bar, the rear got DSE 3" drop leafs, DSE poly shackles and QA1 shocks. here is the only photo of the suspension I have available.
      so my question/problem is, the steering is too light. On the highway the car will want to move at the slightest touch and needs lots of adjustment to any steering input. I got the car aligned. They were only able to get 2 degrees of caster. They told me the frame had likely settled over the years and was maybe a 1/4" out, coupled with the thick shafts on the control arms restricted them from getting any more caster.
      I have been contemplating the Guldstran mod and now which i had done it before I got the alignment. I guess paying twice for an alignment will be my learning cost.
      I have been reading posts, and will continue reading, but I would like some advice on how to improve the steering. I am wondering if a new steering box would help, if the Guldstran mod will help, and is there something else I should consider?
      Everett, WA
      You didn't mention anything about what you are running for a steering box or the condition of the idler arm, inner and outer tie rod ends, etc. Please provide more information.
      The few, the proud, the crazy... the LT1 owners.
      Nov 2001
      Sacramento Ca
      yep. We need to know the state of your steering box, idler arms and tie rods. I had a similar "darty" problem and a little toe-out fixed it.
      Tony Langlois
      1966 Corvair Monza
      Huntington Beach, CA
      If it feels really "light" it sounds like you are maybe running a 3rd gen IROC box?
      That is a common complaint for that box is that it doesn't require enough effort.
      Feb 2008
      los angeles
      the steering box, idler arms and and tie rods are all original. There is no play in the steering box. with the engine off turning the wheel side to side suggests the box is pretty tight, no slop. I was surprised when i purchased the car at the ratio, I think it is only 2 1/2 turns or so lock to lock. Since the car is not a z/28 I thought it would not have had as quick a ratio from the factory. I inspected as closely as possible all the components when I rebuilt the suspension. I didn't see anything of concern.
      Jan 2007
      CT
      [quote=aray327] Since the car is not a z/28 I thought it would not have had as quick a ratio from the factory.quote]
      Mine was a factory RS car that didn't have a quick ration box. Alot of guys would put them in because they were available. I bet someone swapped it out.
      Off topic what type of wheels are those???
      Feb 2008
      los angeles
      Intro's ID 311 with powerder coated gun metal mat finish centers. They have a name for the color but I can't recal it. I started a highly debated thread on why wheels costs soo much, and ended up spending the money on these. They really are worth the money and fit perfectly!
      Central CA USA
      You didn't say if you have power steering or manual steering.
      Is the idler arm good?
      David
      Feb 2008
      los angeles
      I do have power steering. The idler arm seemed fine. Next opportunity I have I will have someone in the car moving the steering wheel while I double check it, but I removed all the steering linkage to clean and paint it and it seemed to be ok.
      Central CA USA
      Sometimes separating the linkage with a pickle fork can damage the joint internally.
      Stock 69 boxes can be very quick, they are variable ratio and 14 to 1 on-center, but something like 10 to 1 off-center. The problem with this box is, the effort level is very light.
      A constant ratio high effort box would be better, look at ATS boxes or for a low cost box that has stiff feel, the AGR box, or a 3rd gen Camaro box with hose adapters and new rag joint to adapt the different size input shaft.
      David
      Feb 2008
      los angeles
      Dave, how do you feel about performing the Guldstran mod with all the other items I have? I am guessing I will be able to get more caster which I believe will help. I only have 2 degrees right now.
      I never use a pickle fork. To separate the ball joints I use a 3/4" bolt threaded into a coupler and force the joints apart by turning the bolt between the upper and lower joints. On the pitman arm and tie rod ends I just soak them with liquid wrentch and keep tapping on the arm or spindle until they fall out.
      What steering box do you recomend?
      Boston MA
      Aside from 2degrees caster, what are your alignment specs?
      1967 #s RS
      Feb 2008
      los angeles
      I don't recall the camber, toe is about 1/8
      Fontana, CA
      Quote Originally Posted by aray327
      In or out?
      Nick R.
      Feb 2008
      los angeles
      1/8 in
      Oct 2002
      Houston,TX
      What was it like before the mods?
      James J.
      Santa Barbara, Ca
      I'd have to ask the same thing, did it feel like this before? I'd assume that would be a yes.
      For one thing, 2 degrees of caster seems really low for an aftermarket control arm setup. I had about 5-5.5 degrees of caster on my '68 with the Global West UCAs. I was able to get 6 degrees out of the AME C5 sub that is in my '67, but I did the alignment myself and took my time to get it spot-on. That's where it comes in handy to be a tech and have access to very modern alignment equipment on the weekend. I must have spend 2 hours getting it right this last time. Positive caster should give you a firmer steering feel and just better overall stability at higher speeds.
      I'd suggest that you get a steering box from ATS that is supposed to give you firm, rack and pinion feel. I'd also replace all the steering linkage while you are at it. If it's original it must have some wear.
      Andy
      Fontana, CA
      ATS' boxes are built by Tom Lee in Sun Valley for us SoCal guys. Save a few bucks on shipping.
      www.leepowersteering.com
      Lee Manufacturing Co
      11661 Pendleton St
      Sun Valley, CA 91352
      I looked and don't see that they advertise increased +caster built into the arms, which could be why 2 is the most you can get without shim stacks from hell on one bolt (which becomes unsafe).
      Nick R.
      La La Land, CA
      Quote Originally Posted by 6'9"Witha69
      Our boxes are built to our specs. If you order from Lee it will not have the same internals that we have found works the best on these cars. Don't get me wrong it will still be kick ass, but it will not be the same due to valving difference, steering stops, and blue printing tolerance that we request.
      Lee also drop ships my boxes direct to the client.
      Tyler
      Feb 2008
      los angeles
      before i made any changes the car sat for 15yrs or so. When I got it running I still had 15+yr old bias ply rubber. As I began tearing into things the ball joints were worn, and several suspension/steering peices were not as tight as they should have been. That would explain why the car felt so loose from the start. The steering was always quick, since I haven't changed the box there has been no difference in ratio. I do have better steering response now but not as good as I believe it should be.
      My dad had a 69 with a quick ratio box, both his and mine feel about the same except my steering is much lighter; and he ran a 6" front rim compared to my 8".
      I was told by the alignment shop that my frame had likely settled over the years and is now about 1/8 to a 1/4 out from original specs. Coupled with the very thick shafts on my upper arms, they were not able to get enough shims in to create more caster. After discussing it with them I suggested pulling the arms and milling the shaft about 1/4 to be able to provide more room for alignment.
      Here are a couple more photos. http://www.cardomain.com/ride/3014561
      This is what I will do: Look again at the steering linkage, idler are, tie rod ends, etc. and replace as needed. Perform the G mod and relocate the upper arms. Look at Lee and/or 80's iroc box. Mill the shafts. Did I miss anything?
