Thread: possible overheating problem
04-28-2008 #1
- Apr 2005
- Bonney Lake, WA
- 135
Ive recently built a new engine for my 67 Camaro, and I am having concerns with my coolant temp. I have a 383 with afr heads runing 9.80 compression. The block has been thourougly cleaned, has a new afco radiator, new mezierre mechanical water pump, new t stat that I believe is set for 195 degrees I have drilled 3 bypass holes in my t stat. I have an black magic electric fan assembly. I am using a auto meter electric water temp gauge. I have installed the sender in the drivers side head towards the front. I am getting readings pushing 240-245. Is the temperture reading different based on sender location? Is head mount or manifold mount a better choice? what are safe temp readings? is that "safe" number different based on sender location? any help here would be appreciated. Thanks Jay.
